What are you tapping for 12V+ on your relays?
Just looking for ideas, I'm running 4 amps and I want 2 of them to be off a switch (the sub amps). What I'm thinking is I'll run a standard relay harness and split the outputs into two wires, one going to one set of amps and the other being re-routed to a simple switch. All that is pretty simple and I've done things like that before but I was wondering..
since the relay is going to be buried somewhere in the center console, there is a cig lighter i NEVER use for anything. Would that be a good wire to get the constant 12v+ from? Or should I keep digging and tap the ignition or something.. that's what I'm running my under-dash led's off of.
What would also be cool is I could remove the metal adaptor from the cig lighter and flush mount the amp switch in there so its basically a hidden toggle for the bass. I already have two bass knobs so I'm not to keen on running another switch in the open... its a driver seat not a cockpit lol. what do you guys think? :shrug:
You may be able to use the cig lighter for a CONSTANT positive. Some lighters use negative polarity or something. if it is negative it wouldnt be a good option without a converter.
for the amps, I would just connect the relay to the headunit's remote turn on trigger.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
my relay is mounted within like 6 inches of my buss bars so i get all my power from those. then i let the headunit turn it on for me. it's switching on 4 amps for me and powering some lights inside my box (see the blue glow in my signature banner)
I ran my Stroker 122 on a 1200w Kicker amp wired to a switch in the cigarette lighter. It worked fine for me :)
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
