stevo2deep Posted March 24, 2011 Report Posted March 24, 2011 I've posted this same question in the Kicker forum and am also awaiting a response from stillwater designs tech department, but I am looking for any input I can get. So the manual says that 10 cubes with 150square inches port 21" inches long tunes to 35hz. I've never owned a solo x 18 before and want to stick to 10c.f. but tune to 30hz. It'll be sub up port back in a 1999 Isuzu Vehicross with a 2500.1 pushin it. There will be a plexi window in front and back of the box so I'd like to stay with this configuration. I'm not sure if a square sub like this works with the box tuning calculator, so my question is what my port area and length would need to be to tune to 30hz. I currently have a L715" in a Tacoma in a 4.5cf box tuned to 32 hz. and I would like to tune just a bit lower. Is it possble that the 18 tuned to 35hz in a big box will hit lower than the 15 tuned to 32hz in a medium size box already? Thanks in advance Quote no you're a towell 99 Isuzu Vehicross FTW DC 5K (would like to be 7.5K) DC 350.4 (2X) SOLOX 18s WALL 17 CUBES (3X) XS D3100'S REAR / (1X) D3400 FRONT Kenwood Excelon flip-out w/rear view and navi Singer Alt FTW TOO LAZY TO LOG BUILD, MAYBE TOMORROW
STEvil Posted March 25, 2011 Report Posted March 25, 2011 (edited) shape of the sub wont matter to how the sub "works" with a box calculator. http://www.the12volt.com/caraudio/boxcalcs.asp Edited March 25, 2011 by STEvil Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
stevo2deep Posted March 25, 2011 Author Report Posted March 25, 2011 shape of the sub wont matter to how the sub "works" with a box calculator. http://www.the12volt.com/caraudio/boxcalcs.asp Thanks that makes sense for the tuning but how the hell fuck do you figure port area for a sub? It seems that sub size and shape would factor in here and I've read on this forum that the solox is very picky about it's enclosure Quote no you're a towell 99 Isuzu Vehicross FTW DC 5K (would like to be 7.5K) DC 350.4 (2X) SOLOX 18s WALL 17 CUBES (3X) XS D3100'S REAR / (1X) D3400 FRONT Kenwood Excelon flip-out w/rear view and navi Singer Alt FTW TOO LAZY TO LOG BUILD, MAYBE TOMORROW
Skrilla Posted March 25, 2011 Report Posted March 25, 2011 Your 18 SoloX won't hit lower @ 35Hz then your L7 @ 32Hz... Box size doesn't matter in this situation. It's all in the tuning. Your box could be 20 cubes, but if it's tuned to 35Hz it's not going to really hit any lower then a 4 cubed box tuned to 35Hz... Port area is the "area" of the port itself. For example, if I had a slot port that was 10" tall and 5" wide, that would be 50in of port area (10x5) Length x Width for area. For round ports it's a little different. if it's a 10" round port you take the radius(divide the diameter by 2) which is 5in, and square it (5x5) which is 25, than times that by pi (3.14) and that equals 78.5in of port area. So a 8" round port would be (4x4=16) than 16x3.14= 50.24in. It's really simple once you get the hang of it. So if you want 150in of port area and you're doing a slot port, you're going to want your port to be something like 20" tall x 7.5" wide (20 x 7.5 = 150in). This will depend on the dimensions of your box, though Quote 2 HDC3 18's AQ2200D
knowledge Posted March 25, 2011 Report Posted March 25, 2011 good info Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
stevo2deep Posted March 25, 2011 Author Report Posted March 25, 2011 Thanks skrilla forilla but I meant how do you determine how much area you need for a certain size box volume/driver. What is theadvantage of a bigger box? Gets louder for some subs? Quote no you're a towell 99 Isuzu Vehicross FTW DC 5K (would like to be 7.5K) DC 350.4 (2X) SOLOX 18s WALL 17 CUBES (3X) XS D3100'S REAR / (1X) D3400 FRONT Kenwood Excelon flip-out w/rear view and navi Singer Alt FTW TOO LAZY TO LOG BUILD, MAYBE TOMORROW
Tek Posted March 25, 2011 Report Posted March 25, 2011 Thanks skrilla forilla but I meant how do you determine how much area you need for a certain size box volume/driver. What is theadvantage of a bigger box? Gets louder for some subs? do 15 square inches per cube. Quote
stevo2deep Posted March 25, 2011 Author Report Posted March 25, 2011 That's what I'm lookin for thanks mang Quote no you're a towell 99 Isuzu Vehicross FTW DC 5K (would like to be 7.5K) DC 350.4 (2X) SOLOX 18s WALL 17 CUBES (3X) XS D3100'S REAR / (1X) D3400 FRONT Kenwood Excelon flip-out w/rear view and navi Singer Alt FTW TOO LAZY TO LOG BUILD, MAYBE TOMORROW
Torres Posted March 25, 2011 Report Posted March 25, 2011 Your 18 SoloX won't hit lower @ 35Hz then your L7 @ 32Hz... Box size doesn't matter in this situation. It's all in the tuning. Your box could be 20 cubes, but if it's tuned to 35Hz it's not going to really hit any lower then a 4 cubed box tuned to 35Hz... Port area is the "area" of the port itself. For example, if I had a slot port that was 10" tall and 5" wide, that would be 50in of port area (10x5) Length x Width for area. For round ports it's a little different. if it's a 10" round port you take the radius(divide the diameter by 2) which is 5in, and square it (5x5) which is 25, than times that by pi (3.14) and that equals 78.5in of port area. So a 8" round port would be (4x4=16) than 16x3.14= 50.24in. It's really simple once you get the hang of it. So if you want 150in of port area and you're doing a slot port, you're going to want your port to be something like 20" tall x 7.5" wide (20 x 7.5 = 150in). This will depend on the dimensions of your box, though box size, tuning, and port area always matter imo Quote
RAM_Designs Posted March 25, 2011 Report Posted March 25, 2011 (edited) box size, tuning, and port area always matter imo Definitely. Edited March 25, 2011 by RAM_Designs Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
