What Electrical Upgrades Would I Need?
I drive a 2002 Saturn SL
Still using stock 90 amp alternator
Big 3 Upgrade in 1/0 gauge
What else would I need to power like 2500 watts off my electrical? Would 2 batteries help? If so which size batteries would you guys recommend?
I plan on running 3 Amps
(2) 1000watt Mono amps and a 320watt 4 channel
Thanks,
Dom
(4) Quantum Audio 1" Tweeters
(2) RF P1 6.5" Speakers
(2) Orion Cobalt 12" CO124s
Audiopipe APSM-4050 (Component Amp)
Audiopipe APSM-1300 (Subs Amp)
model numbers of the said amps?
x2
I would like to know the amps before I suggest anything...
x2
(2) Audiopipe APSM1300 (Subs Amp)
Im limited on space and AP amps usually do rated power, and these amps are extremely small profile amps.
You're going to see voltage drop, that is a very small alternator and having a huge battery bank might burn it out quickly. I would personally, if you're not going to upgrade the alternator, with an XS under the hood, and a D3100 in the back.
Is it possible to leave the stock battery and just put a D3100 in the trunk? or is it better to put the new battery under the hood and not have one in the trunk?
Do you think I could get like 1400watts out of this stock setup for now?
Running just one of the 1k amps and the 320watt 4 channel?
or would i still need battery upgrades?
if you wanted performance and the ability to play daily i would say yes, upgrade the batteries. if you need, place the D3100 in the back and then save up until you can upgrade another link in the chain.
So its best to put one in the trunk. Then later put one under the hood
That is the route I would go. Unless your starting battery is running on its last leg.
  • Who's Online   0 Members, 0 Anonymous, 1258 Guests (See full list)
