I found some pretty cheap vinyl that is 3-way stretch. What is the difference between 3-way and 4-way stretch vinyl? Also found a color that matches my car for 8.95 a yard, is that a good price? This is for my sub enclosure.
SMD Super Seller
My Feedback Thread
not to thread jack, but what site you find it on? gonna be looking for when i do my doors/pillars
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
http://www.yourautotrim.com. Go to automotive seat vinyl on the left side of the page, and then the specialty auto vinyl section.
ok thanks
as for your question, no idea.. dunno what the difference would be tbh.. i would think it would all be the same, unless the 2,3 4 way etc higher the number the more it'll stretch?
Team Sundown Audio
That's a great site for vinyl and everything associated.
The stretch levels are just how the threads are woven in the back I believe. The four way stretch stuff will be your best bet if you have little experience with wrapping. (I'm learning the hard way right now lol)
Make sure you get some good adhesive if you're going to be messing with a lot of curves. (Also...I'm learning the hard way)
Need an install? Hit me up.
[email protected]
yes, it has to do with the backing, and the matting used and placed furing production. vinyl itself is able to stretch and contour with heat, its the backing that keeps the vinyl maintain said contour. three-way backing is normally lines running vertically, horizontally, and one direction diagonally, which allows the vinyl to stretch in 3 different directions. four-way obviously is the exact same thing, except the vinyl is able to stretch out in all directions.
no problem. depending on what im doing, 4way stretch is much easier and quicker to work with. sometimes though, depending on the color or the print, it is not worth the extra $7-$15 a yard for 4way stretch.
