Hey guys, quick question. I'm wanting to get as much out of my JL Audio J2 1000.1 mono amp as possible so I want to run it at 1 ohm. At 1 ohm its rated at 1000x1. I haven't bought my subs yet, but I am planning on running two 12" JL Audio W3V3-2ohm. I believe I know how to wire it, but I can't find a diagram anywhere to verify it. If I were to buy the 2 ohm subs, wire like the diagram below, it would be running at 1 ohm right? Do you guys see any problem with this?
Edited by JasonsKreationz
05 Ram 1500 4x4 Hemi - 22x11 Fuel Hostage wrapped in 37" Nitto Mud Grappler - 3" Dual Flow Master w/ X pipe - 10" lift - Alpine 103BT Head unit - JL Audio J2-320.4 - JL Audio J2-1000.1 - (2) 12" JL Audio W3V3 - (2) sets of JL Audio components - 5% tint - 6000K HID - CAI - and more....
that is correct. just wire the subs in parallel and you will have a 1 ohm load.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
yes you would wire it exactally the way it is in the diagram. the diagram has different impedances than what you will have.
Just do this..
1.) Take the positive and negative of both your subs and connect them both together at the amp. So lets say that the positive of the left subwoofer will be connected on the same terminal as the positive of your right subwoofer. Do the same thing for your negative terminals.
I prefer to connect the subwoofer wires together at the amp because its easier if you are using bigger speaker gauge wire it will be hard to combine them on the subwoofers terminals since the terminals on speakers are so damn small.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Thanks guys!
