Mr.P P-loder....153.7 at 36hz 4 15's 4th order or soemthing
Cant wait for more pix an updates!!!
Also fix ur pix there not showin up at all
2008 Yukon 2-18"s EVILS
TEAM SSA
TEAM AUDIOTEX
Term lab or not...im cutting my port down 6"...screw it...literally its only a couple screws and if it makes a big difference by ear hopefully its a positive result on the TL
DCAUDIO
BALLS DEEP
Soo...i shrunk my port and output is gone...12k i pickup monday then im waiting on the things to hold my batteries might be a few weeks on them tho :popcorn:
plays alot flatter now tho. Its about the same to the ear from low to high...i think my rise went up a turdtonnage because my voltage is alot better. Slow and steady wins the race.
DCAUDIO
BALLS DEEP
hey p befor you try anything eles take up some space on the sealed side smaller or just add some type of fill
trust me i learned a thing or 2 about 4th orders from team bassick joey and alan dante hate alan all you want the mo fo knows about band passes
just curious have you tried to play notes in the 100hz area? I built a 4th order close to this and the peak was higher than I expected. I did a full volume sine sweep and realized i was peaking at 120hz and rolled off after that. I never even gave burping at 120hz a thought. found out my port area was way to big for having such a small sealed side.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
I havent given up yet had a amp scare today sounded like the subs were pop testing themselves...but no protect deck kept shutting off...
pulled the amp and checked all the fets and caps and everything seems cool ?
deck might be the problem but im scared to power the amp on now its a borrowed amp, might send it to someone with a test bench can fire it off with only a couple amps.
DCAUDIO
BALLS DEEP
No i wouldnt dare play over 60hz man that is deffinately not cool, not only do you get out of bandwith weird harmonics, i dont think my level 4's would like...
DCAUDIO
BALLS DEEP
not cool? I dont understand. subs are meant to play that freq. what harm can it do? your box looks like it would play it no problem.
