i have 3 amps hooked up, 2 aq1200ds and a mb quart dsc450. the mb and 1st aq are reading 12.6v with the engine off, the other reads 4.8v. all amps are run of a distro block that goes from 1/0 to 3 4ga wires. is this low voltage on the one normal?
bingo on the power/ground. my distro is under a platform in the back of my truck, somehow, the third power wire came out of the ring terminal, so right know im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. yay!!!
i would solder them on it might save you from having to pull everything out again
87 gmc s15- 6 AB dx 12s-AB 150.1-AB 75.1-AB sq480
extras-crossfire/sundown 15-diamond audio d2 12-AB vfl 1000(hc502)-mtx 2300x
this is so going in my sig.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
wow that sucks... maybe make the terminal more accessible while you're at it? lol
Live life to the full... Then TURN THAT BITCH UP!
  • Who's Online   0 Members, 0 Anonymous, 581 Guests (See full list)
