chrishova Posted April 3, 2011 Report Posted April 3, 2011 Hello, I have a H.O. alt. (220amps) and the big 3 and want to put in a second battery. I need to know how to wire it and do I need a relay, isolator, what? Any wiring diagrams will help. Thank yall! Quote Pontiac Grand Prix GT400a Mean Machine alt. EIGHT DD 12''s on a DDz2DD vo 8''s,6''s,5.25''s&tweetsNorfolk, VAhttp://www.youtube.c...ser/ovnorfolkvahttps://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishovahttp://www.stevemead...__fromsearch__1[/color]
__d_a_v_i_d__ Posted April 3, 2011 Report Posted April 3, 2011 parallel to your other batt. Quote Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
blownengine Posted April 3, 2011 Report Posted April 3, 2011 Parallel. Positive to Positive, negative to negative. 0 gauge preferably. I would also throw some grounds on the second battery too. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
CLNFREAK Posted April 3, 2011 Report Posted April 3, 2011 Fuse after front batt and before rear batt on pos... if you want to (some guys don't) but its the safe way Quote
chrishova Posted April 3, 2011 Author Report Posted April 3, 2011 (edited) So kinda like my old cap?! Do I have to run a Neg from my batt. under the hood to the one in the trunk? Thanks, guys! I WILL fuse it! Edited April 3, 2011 by chrishova Quote Pontiac Grand Prix GT400a Mean Machine alt. EIGHT DD 12''s on a DDz2DD vo 8''s,6''s,5.25''s&tweetsNorfolk, VAhttp://www.youtube.c...ser/ovnorfolkvahttps://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishovahttp://www.stevemead...__fromsearch__1[/color]
blownengine Posted April 3, 2011 Report Posted April 3, 2011 It's a good idea to run a negative as well. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
matt14 Posted April 4, 2011 Report Posted April 4, 2011 So run two fuses inline between the front and rear batteries, then a fuse between the secondary battery to the amp. Should the fuses between the two batteries be the total of what the amps would he pulling, so for instance 300 for the sub amp and 60 for a 4channel for a total of two 360amp fuses? Quote 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
dereileak Posted April 5, 2011 Report Posted April 5, 2011 Follow my guide son Second Battery Wiring Guide Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
sprkn_ranger Posted April 5, 2011 Report Posted April 5, 2011 (edited) Follow my guide son Second Battery Wiring Guide That's a good diagram! And yes, it is a must to fuse as close as you can to each battery. If you don't your gonna have a nice car-b-que when something shorts out. Edit- and each fuse should be rated for what the wire can handle. If it can handle 300A for example, then use a 300A at the front batt, a 300A at the rear, and a 300A between the rear batt and amp (assuming your using the same wire for your amp.) And always fuse as close to the battery's as you can. Edited April 5, 2011 by sprkn_ranger Quote Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
dereileak Posted April 5, 2011 Report Posted April 5, 2011 (edited) Follow my guide son Second Battery Wiring Guide That's a good diagram! And yes, it is a must to fuse as close as you can to each battery. If you don't your gonna have a nice car-b-que when something shorts out. Edit- and each fuse should be rated for what the wire can handle. If it can handle 300A for example, then use a 300A at the front batt, a 300A at the rear, and a 300A between the rear batt and amp (assuming your using the same wire for your amp.) And always fuse as close to the battery's as you can. yea also for the amp fuse, you can lower the fuse rating to what the amp is supposed to be fused for that way really your protecting the amp and the wiring, the rest you just fuse to the wiring, should say that in there Edit: Also to the guy who needs help who started this, dont use isolators they cause lots of issues, drop your voltages, and are a waste of money, the only reason you would want them is for reasons other then car audio Edited April 5, 2011 by dereileak Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
