This is with the box about 95 percent or better done. I have about an hour or 2 left of work on it which will be smoothing out some minor details and then flush mounting the subs. I just like that look. I just can't afford the materials as of right now I plan to possibly do a little bondo work and fiberglass to make everything streamlined and smooth and then I will throw a quick coat of paint on.
1389.jpg?t=1302051784
1391.jpg?t=1302051784
1393.jpg?t=1302051784
holy fuckin fail on the image post
01 Tahoe
Big 3
20 ft.1/0 streetwire under hood
4 Batteries
Stock Battery and
1800 Kinetic Batt under hood
2 Sprinter S12V500F Battery,165 AH
Kicker 1/0 going from front to back
Sirius sportster
Alpine 9886
Kicker 650.4zx mids and highs
Q-Logic kick panels w/Kicker6 1/2 comps.
XXX re comp 6.5 in front doors
Alpine6.5 coax in rear doors
2 Audioque 2200d strapped
2 Audioque 18 HDC3
5% all the way around
2 layers raamat on roof
doors covered in raamat
Anyway, before my system got jacked and just after I had bought my Crescendo I metered a 148.6 sealed on the dash with my old box and old subs. It was dropping to the low 12's upper 11's. I revved it up a bit and it gained me a couple tenths which is when I hit the 148.6.
Nice setup, but doesnt mounting the amps on the box wreck the guts? Just wondering!
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
I've heard the same, And it isn't good to screw directly to the box at all. You can't see it at all but I bought some small about 1/4 inch thick rubber grommets and doubled them up underneath each mounting foot and screwed threw them to absorb some of the shock. I had really no other option to mount them the box takes up the entire cargo area. I tried under the rear seat and it's also a no go. That spot worked fine for my Crescendo but mounting 2 amps under there about the same dimensions as the 3kwp isn't gonna happen.
Sorry to see the break-in. I cannot stand two type of people: 1. A liar 2. A thief. Glad to see you rebound. Lookin pretty good.
Black and white is hurting my brain. :peepwall:
shut up its artsy. have you no culture in your life? :D
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
