MrSkippyJ Posted April 9, 2011 Report Posted April 9, 2011 I didn't realize we were supposed to ignore voltage when considering what wire to use. the voltage is irrelevant. 500watts into 1 ohm is 22amps. 2000watts into 4 ohm is 22amps. yeah you're right, voltage has no bearing on what a wire can handle... F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
bignickk Posted April 9, 2011 Report Posted April 9, 2011 the only problem in running 8 gauge is the subs terminals prob wont be big enough. my 15" hcca barley and i mean barley fits the crappy 8 gauge wire i got going to it. (im running parralel so the terminal with 2 wires is not big enough.) 2000 tahoe orion hcca 15.4 kicker zx2500 2 JL 300/4s infinity and kicker mids/highs KHC1400 in back, stock upfront dont ask about my HU clarion EQ kicker/fosgate rcas
uhoh_45 Posted April 9, 2011 Report Posted April 9, 2011 I didn't realize we were supposed to ignore voltage when considering what wire to use. the voltage is irrelevant. 500watts into 1 ohm is 22amps. 2000watts into 4 ohm is 22amps. yeah you're right, voltage has no bearing on what a wire can handle... from what i see here you you are referring to power wire not speaker wire 2 different things R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
MrSkippyJ Posted April 9, 2011 Report Posted April 9, 2011 fuck me, wrong twice in one day. Yesterday must have been a bad day for me I am reading over what I wrote yesterday and I think I may have been confusing a couple posts or something. Plus I was playing black ops and doing this on my phone. I think I will not do that anymore. I failed this thread on basic damn electronics. Who knows what I was thinking here... F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
TheyDontWantMusic Posted April 9, 2011 Report Posted April 9, 2011 from what i see here you you are referring to power wire not speaker wire 2 different things no I'm talking about speaker cable. the wattage your amplifier is doing is one thing to consider when choosing speaker cable, but the impedance of your sub will determine how much amperage your cable needs to handle, which is how cable is measured. for example, if you had a monoblock amp, rated at 800watts into 1ohm, 500watts into 4ohm, and is a dual 2 ohm sub, you might figure that if you wire it at 4ohm, or 1ohm, it isn't much more power, so you don't need much bigger cable, when in fact. 500watts @ 4ohm is 11amps but 800watts @ 1ohm is 28amps so in fact, although you have 50% more power, you have nearly 3 times the current because of the lower impedance. you can run 10,000watts along 1amp cable, just it needs to be at 10,000volts http://www.sengpielaudio.com/calculator-ohm.htm
MrSkippyJ Posted April 10, 2011 Report Posted April 10, 2011 I think he was telling me that. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
JasonsKreationz Posted April 10, 2011 Author Report Posted April 10, 2011 Well, I went with 10 gauge. That's what the shop told me to use. I'm running the JL Audio J2 1000.1 at 1 ohm on two 12" W3V3-2 subs. 05 Ram 1500 4x4 Hemi - 22x11 Fuel Hostage wrapped in 37" Nitto Mud Grappler - 3" Dual Flow Master w/ X pipe - 10" lift - Alpine 103BT Head unit - JL Audio J2-320.4 - JL Audio J2-1000.1 - (2) 12" JL Audio W3V3 - (2) sets of JL Audio components - 5% tint - 6000K HID - CAI - and more....
uhoh_45 Posted April 10, 2011 Report Posted April 10, 2011 from what i see here you you are referring to power wire not speaker wire 2 different things no I'm talking about speaker cable. the wattage your amplifier is doing is one thing to consider when choosing speaker cable, but the impedance of your sub will determine how much amperage your cable needs to handle, which is how cable is measured. for example, if you had a monoblock amp, rated at 800watts into 1ohm, 500watts into 4ohm, and is a dual 2 ohm sub, you might figure that if you wire it at 4ohm, or 1ohm, it isn't much more power, so you don't need much bigger cable, when in fact. 500watts @ 4ohm is 11amps but 800watts @ 1ohm is 28amps so in fact, although you have 50% more power, you have nearly 3 times the current because of the lower impedance. you can run 10,000watts along 1amp cable, just it needs to be at 10,000volts http://www.sengpielaudio.com/calculator-ohm.htm sorry i was proving your point I think he was telling me that. bingo i was talking to you haha R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
