What would be the best way to paint mdf? I was thinking coat it in resin sand it use body filler where needed then primer and paint! Is there a better cheaper way or would that be the best?
Team Xtreme Amperage
Xtreme Audio Innovations
XtremeAudioInnovations.com
Facebook.com/xtremeaudio321
4 linked c notched bagged
Fiberglass door panels (5 speakers per door)
thats pretty much it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Make sure you sand the bare MDF before putting anything on it. The glue and sealers they use in it will change how things adhere to it.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
Well, bare mdf will soak up the paint, alot...you could always do several layers of primer, then paint. But i believe by the time you spend money on the primer, it will be about the same to do it the right way with resin and body filler. Not to mention, you will be alot happier with those results.
i just painted mine, sanded resin down a bit, thats about it, doesnt look to bad, but i dont really care how it looks aslong as it works
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Thanks for the info! If we decide to paint it ill post pictures!
donell any flat edge needs sealed.
look at this
http://shoryuken.com/f177/how-paint-mdf-mirror-finish-worklog-191692/
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i was going to post that exact thread.
on the last couple boxes i've done, i've covered em in fabric but in the port i just use a roller and roll the paint on. it's thick and doesn't get sucked into the wood. one coat, maybe two is all you need. but if you're gonna paint the outside of it, proper prep work will still be needed
look at this
Thank for the thread it covered everything i would need to know!
  • 3 weeks later...
Well you have a couple of different options.
You could sand it down smooth and spray primer but its going to take some cans of paint. If you have a spray gun you can lay some real coats of primer fairly fast with great coverage then paint the base with some clear on top.
If your going the cheap route, I like to build box's, then sand them down use fiberglass body filler over the screw holes and then get some bed coating and roll it on. It ends up looking really good and if you fudge up a couple of spots it really wont be noticeable.
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(1) Audio Control Line Driver
(4) DC LVL 4 15's
Cresendo Mids and Highs
100' of 0/guage
Big Three
Mechman 270a Charging @ 16.5v
(6) XS D1400's
Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1
Updated JUNE 2012*****MY BUILD LOG
USACI REGION 6 POINTS LEADER 2011
USACI KANSAS RECORD HOLDER 2011
Team DC
http://www.dcsoundlab.com/
