I'll keep it simple.
I have 50' of KNU CCA wire, which I ordered believing it was the OCA wire.
What is the maximum power handling rating for CCA?
If I'm running more than 3k watts, should I return it and get something better?
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
i just ordered 2 50' spools of KCA and they just came today. they are rated to 250 amps. so it really depends on home many runs you put to your rear bank.
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
generally speaking, 1/0 awg ofc wire is rated for 300 amps, 1/0 awg cca wire is rated for 250. for your 3000 rms i would recommend doing two runs to the rear if possible. only 1 run may choke the system some
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I think adding another battery and using Ofc will be a better idea. Like the big 3, Ofc is what I'm using than cca.
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
What size is the wire and what class is your amplifier?
It's really nothing about class, its more of how much rms is the amp rated for.
Edited by carlosg_313
A Class D amplifier is more efficient compared to a Class A/B amplifier therefore you can get more power out using a Class D amplifier. With a Class D amplifier one run of 1/0 gauge wire may suffice but with a Class A/B amplifier you will definitely need two runs of 1/0 gauge.
Edited by Kevin
What I'm doing is running dual runs of knu cca to the rear battery, the from the rear battery run some ofc to the amps. Total rms- around 4500. Will ne doing this hopefully this weekend.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
You should be running the OFC to he back
  • Who's Online   0 Members, 0 Anonymous, 691 Guests (See full list)
