Sound Deadner Where To Get It And Where To Get It Cheap
Ebay is your friend with Sound deadner.
Meglo peal n seal is thick, I would say its very close to the same as dynamat in thickness, I have used mainly dynamate and the stinger roadkill, I used the peel n seal, in my ride because Im a cheap bastard, and it seams to work well if you prep for it and use the correct tools, will it stay on there forever? I dont know, I will never know once I glass the roof.
o so around about how much is it and what kinda prep do u need to do cause where im using it get alot of air my ports are only like 6'' away from the hatch
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Guest MegaloManiac
to prep surface you wipe down surface with a tach clothe. make sure surface is completely clean. the cleaner the surface the better it will stick to. cause if u stick something to a dirt surface, then u r sticking to dirt and not the panel, it WILL definitely fall off. prepping is very important
if you still plan to go Peel-N-Seal route heres the link
http://www.lowes.com/lowes/lkn?action=prod...017-81326-PS625
Edited by MegaloManiac
ebay. peel n seal isnt the best shit by any means. id prolly go with somethin else unless you wanted to do about 3 layers of peel n seal
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
where u can u get it the cheapest than something better
new toy
bagged
22s
REFS
when I pepped my surface I went over everything with Prep-all from Car Quest, and it removes all the oil, dirt, grime, or anything else on the surface. Even Peel and seal will stick great after that stuff. I cant remember how much it was, but it isn't too expensive, and a gallon will be plenty to do your whole car.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
peal n seal ftw
what is that suppsoe to be pics of peel n seel
new toy
bagged
22s
REFS
Its the same thing sept the top one I got from doug instead of foil it has thick fabric it seems to do really well. Ive got flowmasters dumping out under the cab and I can barely hear them. The bottom stuff is another form of peel and seal its more splash guard sealer its rubber and sticks super good but your gonna need 3 layers to = 1 layer of dynamat I ended up putting 2 more layers of the fabrick stuff over the top of it.
  • Who's Online   1 Member, 0 Anonymous, 1820 Guests (See full list)
