Will I be okay running 8 gauge wire into a rockford t1000bd?
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
Not at all.
In general, go for the largest wire the amp will accept...
Edited by S15_Silvia
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
For power/ground? What impedance? At either 1 or 2 ohms, I definitely wouldn't.
Manufacturers recommend wire sizes for many reasons...
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Amp power... HELL NO! 4 gauge minimum and if your run is more than 10 feet 1/0 gauge will minimize voltage drop. Make sure your ground is same gauge! (wish I didn't have to say it but just wanna be sure)
Amp-to-subs, overkill. You won't notice any drop using 12 gauge for speaker cable
2007 Pacifica
I'm just concerned about killing my electrical, bcuz i'm going to run a mids/highs amp too. I don't have the money to drop on a battery or alternator
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
Bigger wire can't kill you electrical, it's just the component of the system used to feed your amps, bigger wire the less resistance.
However using smaller than recommended wire can kill you car, since it can heat up and possibly catch on fire(shouldn't because of fuse but is possible), also just because you use smaller wire doesn't change the strain on the electrical system, it only strains the wire more.
¿ǝɯɐƃ ǝɥʇ
well its recommended to use 4 gauge, so would i be fine running that and just upgrade the big 3?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
id say only if you were running at 4-8 ohms which isnt very practical if your on this website haha
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
Yeah, you'll do OK with that. Normally I'd say go 2 gauge if >10 feet but then people ask me where the hell to find 2 gauge. So 1/0 it is. But if you run 1/0 now, it makes it easier for you to upgrade your amp later, since the cable is already run :good: Definitely do the big 3.
Edited by srp365
2007 Pacifica
