yep same thing happend to me, i just glued and screwed. then fiberglassed the inside and outside of all the seems to seal it up. :good:
15"AA havoc, AQ1200d. T3 audio 6.5 2 way componet set on rockford p400.4
This is what happens when you get wood cut at home depot by someone who doesn't know what they're doing and don't use the right tool for the job.
Fixed 8)
I got my box cut for me by the guys at Home Depot and when I provided the right measurements they cut them all perfectly.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
Did they cut your wood with a jig saw??
Yeah it's fixable I'd seal inside with silicone and outside with sawdust mixed with wood glue. If you got a compressor try using a nozzle after and see if any air leaks.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Get some sawdust and mix it with wood glue and put it on the end that are bad so it can seal it up, make sure you have enough so it squeezes out the sides and then caulk the inside after it all dries up.
x2
x3
Did this on my last box and then for the "cosmetics" of the box i just used wood filler, So now its air tight and looks decent.good.gif
