This is what happens when you get wood cut at home depot. I got all my cuts at home depot and some are 1/16 to short. they wasnt using the regular saw. i was wondering can i use some sealer tape for the cracks?
Probably with fiberglass
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
wtf they didn't use the wall saw?? the ones that go up and down?? jeez man you got raped on that deal.. i have never seen such a bad cut from home depot, i never had any problems with them you should have made them give you another sheet and do it all over again
you can use double sided foam tape. i have before and it works well for testing and stuff. just seal it off with some window caulk for a better seal.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Build the box with wood glue and screws like you normally would. Then buy a jug of fiberglass resin and paint a thick coat of resin in all of the corners on the inside of the box. That should ensure it's sealed up nice and tight.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Get some sawdust and mix it with wood glue and put it on the end that are bad so it can seal it up, make sure you have enough so it squeezes out the sides and then caulk the inside after it all dries up.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Im sure it could be fixed but if you plan on keeping the box I would start over, If this is a lower power handling box than you might be able to deal it with caulk. Id mix wood glue and saw dust and cake it in their from the outside too...
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
I suck at cutting wood so I had a similar issue, fiberglass worked wonders. :pardon:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
