they should come off the same way any other a pillars do the airbag is on the inside mounted to the actual metal in the a pillar and the sensor to set off the airbag is probably in the lower door just dont try to cut any wires or touch and wires to whats in there cause that might set it off
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
yes you can. what vehicel is this.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
disconnected battery to be safe
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yeah I should probably stick with just fabricating the doors.. the A pillars seem a little risky haha. Thank you :)
youll be fine. i take mine off all the time. just dont pull any wires. be careful when you pop them off.. as a matter of fact, the little button that says "side cutain air bag" is how i have to take mine off lol
I don't think I have that button in my car :)
Those come right off
