Infamous ground noise. Help!
Okay so I've tried a couple things already. Put a ground from batt to alt. Replaced a factory ground for radio to a solid spot on the body. Now the noise does go with rpms just an FYI. When I unplug rcas from 4 channel noise stops. I don't seem to have any noise from subs, primarily comes thru tweeters. I haven't tried playing a seperate source to the 4 chan. Any other ideas guys?
The noise started when I got in my car to go home from work. Worked perfectly fine before. Only thing I did was dump water out of my taillight.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
maybe one of your rcas has a short in it
that could be. i did notice that some of the grounding ends on the rca's were loose. (knukonceptz threads theres on)
Team NWSPL
baaudio Build Log
It could also be high frequency noise that your subs isn't picking up because of the LPF on your amp. I would check that out also. If it is coming through your sub preamp too, then it is probably a ground loop somewhere in your wiring job. Also, bad spark plug wires can cause magnetic distortion as well, if they are shot, you may try replacing them as well.
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
ive heard mixed things about knu rcas try and see if thats the problem i use walmart rcas and never once had a problem with any noise
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
i had the same problem once before in my old car, i think i just rewired everything and it worked, i use knukonceptz RCAs never had a problem< i have the karma ss series, when i got em all the ends were alittle lose but i just screw it on tighter, no biggie.
wish i could be more help bro
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
Ya I have the Karma ss ones too. I figured it's the LPf that's stopping it. My sub rca's are kicker z series. But I'll try all that. I may try another hu too.
Team NWSPL
baaudio Build Log
  • Who's Online   2 Members, 0 Anonymous, 1574 Guests (See full list)
