MaliBOOM Posted April 29, 2011 Author Report Posted April 29, 2011 and just because Ive done it, doesnt mean that you can or should. It just seems to me like after rise wiring at 1ohm it would be ok? I wish:-/ www.TheAutoSkin.com MaliBOOM v2"2010 Bagged Malibu on 20s"<< click here<<< Excursion on 42s Build log<<Click here<<< Instagram-@theAutoSkinRyan @TheAutoSkin Owner of The Auto Skin
hdorre Posted April 29, 2011 Report Posted April 29, 2011 and just because Ive done it, doesnt mean that you can or should. It just seems to me like after rise wiring at 1ohm it would be ok? I wish:-/ You cant estimate rise. You may rise to 4 ohms, but you may rise to 1.2 ohms. We cant tell you because of all the variables. I have a question- when your system is at "rest," what impedance does the amp see? Thatll make you think again On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
j_black10 Posted April 29, 2011 Report Posted April 29, 2011 bcz it is physically impossible to run my 8 dual 4s at 2 ohm Have you looked at the way the wiring diagrams for the warhorse work? I don't mean to sound degrading to the research you may have done, but you definitely do not wire subs to a warhorse the conventional way you would with regular amps. I honestly haven't even looked into it as I am not familiar with them. Would I be able to then? Documentation! http://www.kicker.com/sites/default/files/2007%20WX%2010000-1%204in1%20v01.pdf Read up grasshopper Correct info 2 post down!!!! AudioControlRockford FosgateXSPower
n8ball2013 Posted April 29, 2011 Report Posted April 29, 2011 Well if it doesn't work at least it will protect and not poof THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
bkolfo4 Posted April 29, 2011 Report Posted April 29, 2011 Please read!!! And DO NOT DO AS SUGGESTED ABOVE. If you guys do not understand how this amp works, please do not post up and give people wrong info. . .Sorry J_Black The amp is a push pull amp. One output pushes the cone, the other pulls it. All 8 speakers have to be wired with one coil from each speaker on each output of the amp. Using coil 1 on all 8 speakers, wire in a series parallel to get 2 ohms (4 + 4)//(4 + 4)//(4 + 4)//(4 + 4)=2. That connects to output 1. Using coil 2 on all 8 speakers, wire in a series parallel to get 2 ohms (4 + 4)//(4 + 4)//(4 + 4)//(4 + 4)=2. That connects to output 2. The kicker warhorse only powers one coil at a time on your sub. The other coil gets shorted during that time. Each output never changes polarity. . . If you buy this amp, you MUST read the manual and understand it, or call Kicker Tech Support. It is unlike other amps and if not wired correctly, you are going to need recones for you subs and possibly repair on the amp! Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
MaliBOOM Posted April 29, 2011 Author Report Posted April 29, 2011 Damn www.TheAutoSkin.com MaliBOOM v2"2010 Bagged Malibu on 20s"<< click here<<< Excursion on 42s Build log<<Click here<<< Instagram-@theAutoSkinRyan @TheAutoSkin Owner of The Auto Skin
j_black10 Posted April 29, 2011 Report Posted April 29, 2011 Please read!!! And DO NOT DO AS SUGGESTED ABOVE. If you guys do not understand how this amp works, please do not post up and give people wrong info. . .Sorry J_Black The amp is a push pull amp. One output pushes the cone, the other pulls it. All 8 speakers have to be wired with one coil from each speaker on each output of the amp. Using coil 1 on all 8 speakers, wire in a series parallel to get 2 ohms (4 + 4)//(4 + 4)//(4 + 4)//(4 + 4)=2. That connects to output 1. Using coil 2 on all 8 speakers, wire in a series parallel to get 2 ohms (4 + 4)//(4 + 4)//(4 + 4)//(4 + 4)=2. That connects to output 2. The kicker warhorse only powers one coil at a time on your sub. The other coil gets shorted during that time. Each output never changes polarity. . . If you buy this amp, you MUST read the manual and understand it, or call Kicker Tech Support. It is unlike other amps and if not wired correctly, you are going to need recones for you subs and possibly repair on the amp! Brian OHHHHHHH!!!!! That's what I get for not reading......Thanks for correcting me B!!!!! AudioControlRockford FosgateXSPower
CJ18 Posted April 29, 2011 Report Posted April 29, 2011 Fuck no don't you dare do this!!!!! Go read how the amp works before making such a dumbass comment. I'm so fucking sick of these threads about the warhorse and dumbass people that have no fucking clue about how the amp works replying to the thread! bcz it is physically impossible to run my 8 dual 4s at 2 ohm Have you looked at the way the wiring diagrams for the warhorse work? I don't mean to sound degrading to the research you may have done, but you definitely do not wire subs to a warhorse the conventional way you would with regular amps. I honestly haven't even looked into it as I am not familiar with them. Would I be able to then? Documentation! http://www.kicker.com/sites/default/files/2007%20WX%2010000-1%204in1%20v01.pdf Read up grasshopper After looking at the manual, you should be fine!! That amp has 2 speaker outputs, each can have a minimum load of 2 ohms. So if you have 8 dual 4ohm subs, series the coils and parallel 4 of the subs together, that gives you 2 ohms!! So put 4 on each speaker output and you will be good to go!!!
MaliBOOM Posted April 29, 2011 Author Report Posted April 29, 2011 ^^^^^dont be such a dick man. Just a simple question with a simple answer no need to get all crazy about it. Thanks to all that answered I will just stick with getting a PB5K for now www.TheAutoSkin.com MaliBOOM v2"2010 Bagged Malibu on 20s"<< click here<<< Excursion on 42s Build log<<Click here<<< Instagram-@theAutoSkinRyan @TheAutoSkin Owner of The Auto Skin
j_black10 Posted April 29, 2011 Report Posted April 29, 2011 Fuck no don't you dare do this!!!!! Go read how the amp works before making such a dumbass comment. I'm so fucking sick of these threads about the warhorse and dumbass people that have no fucking clue about how the amp works replying to the thread! bcz it is physically impossible to run my 8 dual 4s at 2 ohm Have you looked at the way the wiring diagrams for the warhorse work? I don't mean to sound degrading to the research you may have done, but you definitely do not wire subs to a warhorse the conventional way you would with regular amps. I honestly haven't even looked into it as I am not familiar with them. Would I be able to then? Documentation! http://www.kicker.com/sites/default/files/2007%20WX%2010000-1%204in1%20v01.pdf Read up grasshopper After looking at the manual, you should be fine!! That amp has 2 speaker outputs, each can have a minimum load of 2 ohms. So if you have 8 dual 4ohm subs, series the coils and parallel 4 of the subs together, that gives you 2 ohms!! So put 4 on each speaker output and you will be good to go!!! LMAO.....you're funny!!!!!!!! AudioControlRockford FosgateXSPower
