So my uncle was telling me today that some guy said that he wanted to remove some dings in his car doors. He used a heat gun to heat up the metal and then sprayed that dust remover aerosol can upside down on it (which apparently makes them cold enough to burn your skin) and it just popped out. I guess it was the rapid expansion/contraction of the metal? Do y'all think this actaully works? Kinda cool.
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
I have seen it on youtube a few times, idk if it works for real or not. I wouldn't try it. Its much harder than it sounds.
I'm too sceptical to try it, but it sounds like it might work if you were lucky.
Cadence FXA1600.2
Cadence S2W10
lol thats cool. We use the air spray cans, upside down to reset thermal limit switches in ovens, and microwaves in appliance repair
It does the same thing, a spring inside that bends due to the rapid temp drop, and it works pretty good
I would assume this would work for dents too when done right
will only work for small dings and every so often larger dent that JUST formed....metal has memory. it will stay that way, so I wouldn't try it to a pre-existing dent....and when metal dents, most of the time it expands which causes it to never be able to just "pop" back into place. the method is working on the theory of expansion and contraction, but alot of times, the metal just expands too much
Edited by mbdblue
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Old country version that works about the same. Park in the sun in the summer and let the metal get nice and toasty the rub dry ice on the dent and it will pop out. And ya its the expansion/contraction that allows the metal to do that. But ya it definitlry takes timing to work 100% right.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Yeah that all makes sence. I might try the old country version just for the hell of it. Cool that y'all use them on ovens and stuff too...multiple uses.
Cadence FXA1600.2
Cadence S2W10
Ive tried it and it did not work for me.
i used this stuff. a 3 second blast lowered the temp of a thermocouple to - 45C
DC.jpgDC POWER
