I have the general idea on how to fiberglass, I know you have to lay the fiberglass cloth over the area i want to fiberglass, then lay a couple of coats of resin over it, but do you sand it once it drys or am I missing a step, do I have to always apply the clothe if i'm sealing the inside of the box. how long do I wait til I can began to sand. I'm looking into making custom door panels and A pillars and and making custom boxes. If I'm going to do something, I want to do it right the first time. I think I pretty much get the concept, I just want to see what I'm missing. thx
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
I guess i should have scanned the threads first
Mechman 320A
OEM AGM
if one layer drys, you have to sand. but you can do as many layers, at once, as you want as long as the previous layer isnt dry.
use mat, not cloth.
you dont need fiberglass inside the box most of the time.
its not about coats of resin. you just need to get the fiberglass wet. you dont want gobs of resin. using a cheap paint roller works very well to apply an even coat of resin and push out all the air bubbles.
that helps alot
Mechman 320A
OEM AGM
Make sure you cut the mat into small peices. And pre fit it to see how it folds. The best way is to soak the peices. But its messy. Use a paint brush and get a good layer of resin then put the mat then dab it with more resin till its glossy.
i wonder if I can get most of this stuff at my work (Home Depot)
Mechman 320A
OEM AGM
you can, thats where i usually go. its not the best stuff but it works just fine.
I got all of my stuff there :) Not the cheapest location for fiberglass mat or cloth but works fine.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
