08tahoe Posted May 5, 2011 Report Posted May 5, 2011 what amp would you guys recommend for 2 12inch w7's. i just have them sitting in my room but when i save up some money i need a new amp for them. they are 3 ohms each so i was planing on wiring them in parallel to get a 1.5 ohm load
08tahoe Posted May 5, 2011 Author Report Posted May 5, 2011 i forgot to mention that theyre 1000rms each
Dan2427 Posted May 5, 2011 Report Posted May 5, 2011 A cheaper route would be the AQ2200D. Very solid amp and good dollar to watt ratio! If money isnt a big deal you could always get the 1000/1's 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
08tahoe Posted May 5, 2011 Author Report Posted May 5, 2011 A cheaper route would be the AQ2200D. Very solid amp and good dollar to watt ratio! If money isnt a big deal you could always get the 1000/1's thanks, i just looked at the aq2200 but the bad thing is that i cant wire the subs down to 1ohm and i wanted at least 1000 to each. and the 1000/1 is nice but id need 2 and thatd be a grip of money. at first i was thinking i wanted a jl hd1200/1 to each sub but it never came out. and now that i found this site i wish i wouldve not got the w7's and bought something better (underground) like what other people are running here.
dolarbilz Posted May 5, 2011 Report Posted May 5, 2011 Origianly w7 12 were rated at 750watts.now they bumped them to 1000 watts.I think ull be fine with aq2200 if want more get dd m3a or aq 35000.
Rockford_T2D212 Posted May 5, 2011 Report Posted May 5, 2011 A cheaper route would be the AQ2200D. Very solid amp and good dollar to watt ratio! If money isnt a big deal you could always get the 1000/1's thanks, i just looked at the aq2200 but the bad thing is that i cant wire the subs down to 1ohm and i wanted at least 1000 to each. and the 1000/1 is nice but id need 2 and thatd be a grip of money. at first i was thinking i wanted a jl hd1200/1 to each sub but it never came out. and now that i found this site i wish i wouldve not got the w7's and bought something better (underground) like what other people are running here. look at the T1500bdcd id a great amp solid power they rate at about 1800 RMS Chevy Blazer 2001 1 T15k amp 8 T2D212 subs 2 T1000.4 Rockford amps 2 sets of Hertz MLK 165 6 Kenetic 2400's lab metered 154.8 DB
08tahoe Posted May 5, 2011 Author Report Posted May 5, 2011 Origianly w7 12 were rated at 750watts.now they bumped them to 1000 watts.I think ull be fine with aq2200 if want more get dd m3a or aq 35000. thanks imma check out those other amps you mentioned
TeamHT Posted May 5, 2011 Report Posted May 5, 2011 no need for an AQ3500 on those w7s. an AQ2200 would be a good fit. i would invest in upgrading the electrical but the amp is slightly underrated. even at a nominal 1.5 ohms you should get more than close to 1000 watts per woofer. Tell me...does this smell like chloroform to you?
08tahoe Posted May 5, 2011 Author Report Posted May 5, 2011 A cheaper route would be the AQ2200D. Very solid amp and good dollar to watt ratio! If money isnt a big deal you could always get the 1000/1's thanks, i just looked at the aq2200 but the bad thing is that i cant wire the subs down to 1ohm and i wanted at least 1000 to each. and the 1000/1 is nice but id need 2 and thatd be a grip of money. at first i was thinking i wanted a jl hd1200/1 to each sub but it never came out. and now that i found this site i wish i wouldve not got the w7's and bought something better (underground) like what other people are running here. look at the T1500bdcd id a great amp solid power they rate at about 1800 RMS thanks i took a look at this one also
08tahoe Posted May 5, 2011 Author Report Posted May 5, 2011 no need for an AQ3500 on those w7s. an AQ2200 would be a good fit. i would invest in upgrading the electrical but the amp is slightly underrated. even at a nominal 1.5 ohms you should get more than close to 1000 watts per woofer. so you really think one aq2200 would be good for them? cause that is a good price for that amp
