2 - DC XLs on 2 - AQ2200D
C.Sanchez.A
Hey, I'm going to be getting two 12'' DC XLs. I'm going to power them with a AQ2200D each. My question is is it better to strap the amps together or run each sub off it's own amp?
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
if you strap them you only have to set the gains on one amp all of the settings on the first amp will be sent to the second and the second amps settings will be bypassed
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
strap because higher power at higher ohm 4400 @ 2ohm x1 or 2200 @ 1 ohm x2 less strain on your eletrical
This is not true
When you strap them the final load is split in half so each amp sees one ohm when strapped at two ohms
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
