alright guys i have a question about voltage drop
this is what my electrical will look like for my system
if i can get a 400amp alternator
2 new max AGM 200ah batteries thy weigh about 150 pounds each in the back so thats 400ah
1 95 ah in the front
6 or more runs of 0 gauge and big 3
ima b running around 8000rms or higher depending on voltage
know do you guys think ill have a huge voltage drop or a not to bad voltage drop
ima trying to run a SD 8000.1 its rated 8000rms at 12.6
still learning a thing or 2 guys so thanks for your help
Edited by kevin ribeiro
I think you should be okay with that, but I don't have experience with that much power...
only 1 way to find out right hahahha ima see what it does hopefully next month ima do this build a
SD8000,1 vs a DC audio level 6
A 400 amp alt is fine for 8kW, but you'll run into voltage issues at idle.
What kind of batteries? Amp hours mean nothing.
3 runs of + and - are sufficient.
And with said electrical, yes, you will have significant voltage drop at full tilt. 400A charging @ 2k RPM will hold its own for a while, however.
Here's my 10k setup:
320A alt
5x HC2400s
2 runs +/2 runs -
Big 3, buss bars, etc.
I can run decently at idle, but I can't demo for hours. Worst I've seen is 12.9 under heavy abuse before I kill it.
Need an install? Hit me up.
[email protected]
320A alt
5x HC2400s
2 runs +/2 runs -
thanks for your advice and im in brasil i can send you the link on there website but ever thing is going to be in portugues http://www.newmax.com.br/baterias/br/pages/baterias_12v.asp
thats not to bad man 12.9 full tilt for hours im not going to play the system full tilt a lot i just want to give a lot of demos and go do some compotetions what subs and amps are you running
Eight DC LVL4 10s on two Memphis 4Ks. The 10kW come from my five 4-channels.
thats pretty badass man
ima run a DC audio level 6 18 on a sd8000.1d i needed to know what a SD8000.1 at 14.4 volts does i dont want to run over 9k on the sub 9k down would be nice 10k just to risky ima to far away for a recone hhahahhahaha
8k on one DC lv6 18... I'm interested :)
Not sure about the batteries but only way to know is to do it and see what your voltage looks like and if need be add more batteries.
the batteries should get the job down but if not ill put 1 more in but they should be good lets see what happens
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
