alright guys i have a question about voltage drop
this is what my electrical will look like for my system
if i can get a 400amp alternator
2 new max AGM 200ah batteries thy weigh about 150 pounds each in the back so thats 400ah
1 95 ah in the front
6 or more runs of 0 gauge and big 3
ima b running around 8000rms or higher depending on voltage
know do you guys think ill have a huge voltage drop or a not to bad voltage drop
ima trying to run a SD 8000.1 its rated 8000rms at 12.6
still learning a thing or 2 guys so thanks for your help
Edited by kevin ribeiro
I think you should be okay with that, but I don't have experience with that much power...
A 400 amp alt is fine for 8kW, but you'll run into voltage issues at idle.
What kind of batteries? Amp hours mean nothing.
3 runs of + and - are sufficient.
And with said electrical, yes, you will have significant voltage drop at full tilt. 400A charging @ 2k RPM will hold its own for a while, however.
Here's my 10k setup:
320A alt
5x HC2400s
2 runs +/2 runs -
Big 3, buss bars, etc.
I can run decently at idle, but I can't demo for hours. Worst I've seen is 12.9 under heavy abuse before I kill it.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
320A alt
5x HC2400s
2 runs +/2 runs -
thanks for your advice and im in brasil i can send you the link on there website but ever thing is going to be in portugues http://www.newmax.com.br/baterias/br/pages/baterias_12v.asp
thats not to bad man 12.9 full tilt for hours im not going to play the system full tilt a lot i just want to give a lot of demos and go do some compotetions what subs and amps are you running
Eight DC LVL4 10s on two Memphis 4Ks. The 10kW come from my five 4-channels.
thats pretty badass man
ima run a DC audio level 6 18 on a sd8000.1d i needed to know what a SD8000.1 at 14.4 volts does i dont want to run over 9k on the sub 9k down would be nice 10k just to risky ima to far away for a recone hhahahhahaha
  • Who's Online   1 Member, 0 Anonymous, 828 Guests (See full list)
