hershy314 Posted May 8, 2011 Report Posted May 8, 2011 I was out driving around and noticed that the music coming from the rear seemed to sound real crappy, so when I got home I pulled the subs and re-checked the wiring, everything turned out fine. To me it sounds like I screwed up something. It could be that I don't have these in a proper enclosure, but really not sure. Any thoughts? http://athphotography.deviantart.com/ http://www.youtube.com/user/hershy314
Guest Posted May 8, 2011 Report Posted May 8, 2011 i dont understand....how are you powering these subwoofers without an amp?
blownengine Posted May 8, 2011 Report Posted May 8, 2011 uh....... What? Can you explain better what is happening? What equipment? 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
KnockinthaStreetzof608 Posted May 8, 2011 Report Posted May 8, 2011 i dont understand....how are you powering these subwoofers without an amp? im asumming from the headunit ??? if now then i have no clue CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Relyks Posted May 8, 2011 Report Posted May 8, 2011 amps not putting out clean power? more info... --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Azagtoth502 Posted May 8, 2011 Report Posted May 8, 2011 If it was only powered off the radio, then you may have given the subs too much distortion which can be bad. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
blownengine Posted May 8, 2011 Report Posted May 8, 2011 If it was only powered off the radio, then you may have given the subs too much distortion which can be bad. A full 14 watts of head unit powaaaaaaaaa! 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
hershy314 Posted May 8, 2011 Author Report Posted May 8, 2011 yeah its powered off the head unit, really did it too see what would happen. Set up right now is a Pioneer head unit, T3 Audio 5x7 coaxials, and a pair of Hifonics 12 inch subs. This is what it sounded like when I first did it. My link http://athphotography.deviantart.com/ http://www.youtube.com/user/hershy314
bumonskateboard6 Posted May 8, 2011 Report Posted May 8, 2011 You're sending a full range signal to subs? Lol Also most head unit amps are not designed to work well below 4ohms Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
hershy314 Posted May 8, 2011 Author Report Posted May 8, 2011 If I did it right the subs should be seeing 4 ohms each http://athphotography.deviantart.com/ http://www.youtube.com/user/hershy314
