If its the wire going from a front batt to the amp in the rear then the fuse should be near the battery. However in the op's case i believe his batt is in the trunk with his amps and if so i would just fuse it right before the amp.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Ok I what if the battery is under the back seat? My car's battery is under the rear seat. Is it still ok? Also, I used my full length of wire instead of cutting it so around 17 ft of 0 gauge wire from the back seat to the trunk LOL
In that case i would ground it right at the battery since you have all that wire floating around. Dont want to take a chance of it getting cut and shorting out on your body.
Alright fair enough. Thanks!
Not a problem man.
eh?
the rear battery to amplifier cable needs to be fused as close to the rear battery as possible.
if you're fusing 3 feet from the rear battery, you're leaving 3 feet of cable to short out and start a fire, or in the event that the cable comes loose from the fuse holder in the event of an accident.
you need to fuse the rear battery to amplifier cable as close to the battery as possible.
Not a problem man.
im still confused. fuse holder by batt or amp? (on the aq2200d) or both
Edited by Jmoney2544
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Not a problem man.
as per my above post, fuse it at the battery.
as close as possible, 2 or 3 inches if you can manage it.
and do i fuse it at the amp to?
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
