I've come up with a new box design that will allow me to fire my sub forward and seal it off. The only issue is I won't cut any metal and to make it fit i'll have to use 1/2"mdf for the top and bottom of the box. The rest of the box will still be 3/4" plus a double baffle. Will this work ok with enough bracing? Thinking I should resin the inside as well. Feedback please.
SMD Super Seller
My Feedback Thread
Alright, been doing some math and I can't build it 12.5" high. The top and bottom pieces gotta be max 1/2" so I can fit it in, get the airspace I need, and have the box be removeable. So besides NeoFrog's idea, is there a kind of wood I can use that won't flex at 1/2" thick? Some kind of hard wood that doesn't cost a body part.
SMD Super Seller
My Feedback Thread
i would say birch but that does cost a body part lol
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
You cant double it up? Are you that tight on airspace?
If you cant then just brace brace brace the hell out of it.
Are you only running a single 12?
Big 3 with Yellow Top
Im thinking Birch, too. Just save up a little for it.
MAX height is 12.5. The box would be 13 high if I used 3/4 mdf. I can't lower overall height, because I lose too much volume and I want to be able to remove this thing.
Yes, single 12 firing forward, it'll be sealed off of course.
SMD Super Seller
My Feedback Thread
A single 12 shouldn't rip that box apart. Some bracing should do.
I jsut had the idea to use some solid angle iron across the pieces as bracing. That stuff shouldn't allow panel flex.
a max height of 12.5 is fine for 3/4 mdf. your sub cutout will be 11 and an eighth if your routing the hole out just rout through the sizes a 16th top and bottom and your golden. honestly an easy box to make work. just make sure your front face is the 12.5.
If your double baffleing you really dont have to worry at all about height because again its only a 11 and an 8th cutout for the sub the mounting will be within your 12.5
The problem is I need that extra 1/2" for box volume. My width and depth are already maxed out. If I use 3/4, it will fit, but I will have only 1.4 cubes. With the thinner wood, my volume is 1.68, pretty close to almost too small. I need to be able to take it in and out through the trunk.
SMD Super Seller
My Feedback Thread
