Sq Help Ray
WOULD 2 15 Q OR 3 12 SSD BE BETTER FOR SOUND QUALITY
SHOULD THE BE SEALED OR PORTED
KENWOOD DDX 7019
FOCAL 165K2P IN FRONT
FOCAL 165 V2 REAR
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
why not 2 ssd?
3 JUST FOR SHOW I DONT REALLY HAVE ROOM FOR 15'S PORTED I HAVE ONLY 5.8 CUBES IN THE TRUNK AVAILABLE I KNOW Q WORK IN SEALED BOXES BUT DO THE SSD 15
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
please do not type in caps it makes it appear as your yelling
NoFearX18 said:
trainman0978 said:
I think the 12's sealed would be more forgiving to get the sound right then the 15's.
Not saying that you couldn't do it with the 15's but they tend to get muddy easily.
Guest MegaloManiac
you shouldnt need 2 Q(15s) a single 12 can be enough for SQ. the only time i have seen 2 15s being used for SQ is with the IDQs, and thats only cause they dont handle a lot of power. I know 1 person that competes and she is using a single 15. she chose the 15 because the 15 has a lower extension.
And if you are wanting pure SQ Fi would not be the way to go. But if you must go Fi, the Q is the line to look into. But you'll yield far better results using an RE SE, Si Mag(use this if you want to have a bit more output), IDMax,or an IDQ.
also since you are wanting rays opinion, i read that the new Hertz sub (i forget which model, but its from Mille line)is an very excellent & accurate SQ driver.
edit: it was the ml3000
Edited by MegaloManiac
  • Who's Online   1 Member, 0 Anonymous, 1257 Guests (See full list)
