Simply, my truck has been converted to run a 14v system. It charges between 16.2-16.8 volts. Does anyone know the operating range for a Viper 5701. Non of my local Viper dealers can help and Directed has no direct contact info that i can find at least.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
i have the 5901 on mine running on a 14v setup with the same voltage levels as you with no problems daily. i think its safe
2004 Chevy Trailblazer:
Deck: Pioneer Premier DEH-P980BT
Mids: 4 Selenium 6W4P's
Highs: 2 AQ Tweeter's + 2 Crescendo Tweeters + 2 Power Acoustik NX-5 Bullet Tweeters
Highs Amp: MB Quart Onyx 4.125
Bass: 2 18" DC Audio XL's <-- Soon to be 8 Sundown SA-12's
Box: 13.37 Cu Ft @ 35 Hz with 3 8" sonotubes
Bass amps: Crescendo BC3500 @ .5 ohms (2nd one coming soon)
325a Singer Alt! 375a at 16+ volts!
2 XS Power D1400's
www.youtube.com/user/phukudmss
  • 1 month later...
if you read the manual it says the voltages that it will operate at, think the highest they recommend is like 15.5
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
what about a few resistors with high tolerance in parallel to make a ~ .5 ohm load?
http://www.parts-exp...artnumber=016-5
ten of these in parallel would = .5 ohms with a 100 watt rating
At 16.8v you would be at 14v after the resistor, and at 14v rest you would be at 11.7
that would work :P just make sure like you said, they are high tolerance, so they are gonna be some bigger sized resistors
Pioneer 4300DVD
The only problem i see is Door trigger inputs and trunk inputs will be read at 16v when a zone is closed/open
Wouldn't 16.2-16.8 volts be bad for the vehicles electrical system? Consider a step down module or 2.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
No its fine, for my truck at least. Look at Mechman, they have several vehicles they run at these voltages with no problems. I don't have any issues until my voltage reaches around 17.3, that only happens on very cold mornings though.
d(-__-)b
