Jmoney2544 Posted May 26, 2011 Report Posted May 26, 2011 What is the minimum distance for the subs to be facing the rear of your trunk lid to still work effectively? is it better to give them more room or less? like 1 ft away from the trunk lid, or 2 ft? does it matter? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
412 CVX Posted May 26, 2011 Report Posted May 26, 2011 What is the minimum distance for the subs to be facing the rear of your trunk lid to still work effectively? is it better to give them more room or less? like 1 ft away from the trunk lid, or 2 ft? does it matter? honestly it doesn't matter too much as long as the subs have some adequate room to work. but if it were meeee i'd place the subs farther back, becausseeee less annoying trunk rattle and more opportunity for the wave to fullen Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
fritosaregood Posted May 26, 2011 Report Posted May 26, 2011 its just something you have to test, my car gained alot when i closer to the back, but too close hurts it. so just move it back and forth till you cant notice a difference in sound. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
kr15 Posted May 26, 2011 Report Posted May 26, 2011 I have heard at least the ports width from any loading area Team Flex Issues Low tuning > God 2011 CALI AS1 STATE CHAMP
OBI Posted May 26, 2011 Report Posted May 26, 2011 I have heard at least the ports width from any loading area Not true in every single applications. Its just a rule of thumb. I built a box for my brother in law, that actually got louder the closer you moved it to his trunk lid. Shit the subs were almost hitting the truck with how close they were.
412 CVX Posted May 26, 2011 Report Posted May 26, 2011 I have heard at least the ports width from any loading area Not true in every single applications. Its just a rule of thumb. I built a box for my brother in law, that actually got louder the closer you moved it to his trunk lid. Shit the subs were almost hitting the truck with how close they were. that's interesting any theory as to why that happened? Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
samslowp1s Posted May 26, 2011 Report Posted May 26, 2011 its just something you have to test, my car gained alot when i closer to the back, but too close hurts it. so just move it back and forth till you cant notice a difference in sound. I don't have a high power system by any means but, the closer to the backseat I push my box, the louder it got. If I move it closer towards the trunk lid the less impact it had. You just have to find your sweet spot, move it around and find what best works for you.
