DB DON'S Blazer (the pictures)
Just wanted to say thanks for doing what you do and being so helpful :drinks:
~~~~CHODE FTW~~~~
DC4LYFE
I saw how the port wraps around the sub in a way and was curious of that, so that makes sense. It's jut impressive as hell that this is a daily driver, goes off roading/mudding, trip to the grocery store, and then pulls 160s. :lol: Blows me away.
I'm looking at getting 3 18s in 19 net after port, with one layer of 3/4 wood fiberglassed for strength in the back of my civic. Wanted to get your insite if I'd be better off with just 2 in a wall @ 19 for more efficiency or am I gonna be better off with the 3 18s. Been wanting to hear your thoughts on it for a while. :popcorn:
For lower than rated power your box options open up a bit more. you always want to go no less than 6.5" in the front wall thickness before adding port length, it just seems to be a good thickness 8) 8) (Back wall thickness is also equally important.)
I would probably do the 3 with that space, its probably gonna be better in the end when you want to add power. and it still leaves you room to play with port area to find that magic area.
-Donald Hebig1989 Blazer S10 4x4-Four Fi BTL N3 15" "Ruthless bass!"-Four pair of American Bass VFL 8", 6.5", and tweets-Sundown SAZ 1500(2550wrms=156 dB) 92+ Psychlone RTA. Fully off-road capable street build. Built for music.-----------Bringing Sound Quality to a whole new level.--------------dB Drag: Personal best 161.3 sealed up and 158+ Bass Race.USACi: -Canadian SB5 Record holder-Canadian SM 4001+ Record holder
Right back at ya! :drinks:
So is that a general rule you use when building a wall, and the reason your port and baffle are made with so many pieces of wood? You add enough baffles to make the 6.5" in the front and the back, then you do the math for your port to see how much longer it needs for your wanted tuning and cf. Is there an added reason for making the baffle and rear wall so thick other than the "tubes" as you said earlier and maybe strength?
Damn Don...that is straight slapping. Amazing with an fs in the mid 50's the n3's are still musical. I'm guessing the n2 would be better suited for a 4th order? I'm in the market for new subs for my build...leaning heavily towards crossfire because of the 4inch coil...but your setup is nasty...good stuff
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
Don't know if it matters to you or not, but the N3 does have an option for a 4 inch coil.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Damn... makes me feel good that theres people out there taking amazing sounding systems above and beyond...
Thanks for posting all this dude :drinks:
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
is the 4 inch coil an option on the n2? I need a woofer with a softer suspension..the hd's I have are to stiff for a 4th order, figure the n3 has a stiff suspension as well..good info though
2 Stetsom 14k2e's
alpine ina-w910
link to build log:
My link
