Elrey7698 Posted June 4, 2011 Report Posted June 4, 2011 So i finally got my o-scope yesterday and i was up fixing my gains now my problem is that some of my music clips...i play alot of spanish music and i wanted to know what program is good to fix the clipping? Quote
canderton01 Posted June 4, 2011 Report Posted June 4, 2011 I used to use MP3 gain and it worked pretty well. It basically just makes your music quieter to reduce clipping. Audacity could work too. Quote 2002 Camry XLE 35% tints all around 17'' Enkei FD-05 rims Fi Q15 in 3.8cu ft box tuned to 32Hz Pioneer DEH-P7200HD AudioQue AQ1200d 4 Gauge Tsunami wiring/RCA's mids/highs - OEM JBL system AudioTechnix Deadner Big 3 upgrade My YouTube
Decaf Posted June 4, 2011 Report Posted June 4, 2011 you cannot fix clipping, u can make it quieter tho well technically there is a method that works with some songs, but it degrades quality alot just because the red disappears on audacity doesnt mean u got rid of the bad stuff... and just because you see a little red doesnt mean it will even be audible. u need to watch music through a oscilloscope like on windows media player and watch for horizontal flat spots... thats a sign of a song not to play at full tilt Quote
Baydestrian Posted June 5, 2011 Report Posted June 5, 2011 sometimes I see bass lines that aren't horizontal, they are kinda slanted, what does that mean? Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Elrey7698 Posted June 5, 2011 Author Report Posted June 5, 2011 you cannot fix clipping, u can make it quieter tho well technically there is a method that works with some songs, but it degrades quality alot just because the red disappears on audacity doesnt mean u got rid of the bad stuff... and just because you see a little red doesnt mean it will even be audible. u need to watch music through a oscilloscope like on windows media player and watch for horizontal flat spots... thats a sign of a song not to play at full tilt I see...i play alot of banda and spanish music so most of the abuse goes to my mid and highs...guess i just have to be carefull with my epicenter knob...also where can i get some of this "decaf" music i keep hearing about...im guessing ur the man to see...? Quote
Baydestrian Posted June 5, 2011 Report Posted June 5, 2011 his thread stickied at the top of Tunez lol Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Decaf Posted June 5, 2011 Report Posted June 5, 2011 sometimes I see bass lines that aren't horizontal, they are kinda slanted, what does that mean? ideally waveforms should like like a smooth wave, not a triangle or sawtooth if thats what u mean when viewing it on WMP both introduce weird harmonics (odd order) I see...i play alot of banda and spanish music so most of the abuse goes to my mid and highs...guess i just have to be carefull with my epicenter knob...also where can i get some of this "decaf" music i keep hearing about...im guessing ur the man to see...? epicenter will destroy a sub if used on the wrong song, seen it happen first hand on michael jackson a few years back Quote
Autruche Posted June 5, 2011 Report Posted June 5, 2011 When using audacity I've negatively amplified a song and used the 'leveler' effect on the light or medium setting and it seemed to help take some clipping/triangled waves and fix them. Not sure if it actually fixed them or if it just made it a little harder to see, but it seems to have worked a couple times for me. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Decaf Posted June 6, 2011 Report Posted June 6, 2011 (edited) just makes things smaller... which makes it harder to see if you generate a sine wave you can test how each effect changes a single raw note... the leveler makes the waveform less ideal, spends more time at peak position for some reason normalize seems to be a better option, but it acts just like the amplify effect ive spent a large part of the past 3 years using every effect on that program and theres still no correct way for every song Edited June 6, 2011 by Decaf Quote
