so i have a bettery charger that i can set to charge anywhere from 9v-18v and i had it sitting on my car battery charging it at 16v ended up with a 13.6 resting so that was pretty sexy. but it being a 12v battery im asuming it doesnt like to have that high of a voltage.
so ive been pondering the idea of a 18v neon. i have a 98 neon and im wondering what i would need to do to run a 18v battery upfront and have it charge at 16-18.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Your car will not like 18v, what people do is, run 12v on the car then 18v to the amps, whichmeans youll need a step down modual, MOST people who run 18v do it for comps only, not daily driving
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
^ agree
For daily use just stay at normal voltage.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
Why exactly wouldn't you want an 18 volt system for daily? I would think if its set up correctly, you wouldn't have a problem.
I don't doubt what you're saying is the case, I'm asking more about the why factor.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Like mentioned, you wouldnt run the car electronics at 18v+, just the system. I can't see how it would be worth the trouble unless you were pretty serious about shows. Alt(s) and extra battery(s) work wonders.
I screw and tune music a bit for fun. All uploads clip free from 60ish down to under 5hz (all music). Everything from 80's hip-hop to modern stuff. More genres coming soon! Feedback appreciated
http://www.youtube.com/user/RacinJason1971
One reason I wouldn't do 18 volts daily. It's for daily reason what if u need jumping cables no one can help u and u can't help no one. Or can they charge it from the step down?
im not talking about running my whole electrical off 18v just having my alt charge at 18v and the battery be an 18v battery sending 18v to the amp. so id want to run the cars electrical off 12v. ive seen some batterys that have both 18v and 12v tabs anyone ever used these
If you have 18v batts then you will have to charge them at 19.6 or 20volts.
You can't charge a 18v battery at 16-18v. That's what 14v batteries are for.
i wasnt aware of that but if thats what i need then thats what ill do now i guess the next question is where do i find an alt for my 98 neon to charge at 20v
  • Who's Online   0 Members, 0 Anonymous, 873 Guests (See full list)
