Supercharged DCs Posted June 8, 2011 Report Posted June 8, 2011 Though we all have our own fuse recommendations, make sure it is AT LEAST 200A. 0 gauge wiring IS a must, along with the Big 3 in 0gauge and an upgraded battery under the hood/in the back. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
__d_a_v_i_d__ Posted June 8, 2011 Report Posted June 8, 2011 anything is better than ur 60Amp fuse Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
Supercharged DCs Posted June 8, 2011 Report Posted June 8, 2011 God, I can't get over the fail. Seriously lol...... Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
uhoh_45 Posted June 8, 2011 Report Posted June 8, 2011 a 60 amp fuse is roughly good for 600 watts R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
skittlesRgood Posted June 8, 2011 Report Posted June 8, 2011 ok... some important info is being left out or communicated poorly here. 4awg should NOT get a 200amp fuse. i wouldnt go over 100amps. 125amps if you know you have good OFC wire. now that amp can draw something like 150-200 amps so you can burn up that 4awg wire. and that can burn your car down, no joke. so like the others said. you need 0awg wire and a 250amp fuse. im guessing you will probably buy cheap wire so i wouldnt go up to 300amps. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Blackedout Posted June 8, 2011 Report Posted June 8, 2011 The reason you blew your fuse is because you're pulling more than 60 amps through it. It did exactly what it was designed to do, break when the amount of current running through it exceeds ~60 amps. Everyone is saying replace the fuse. Cool, replace it... But I wouldn't replace it with anything higher than 100 amps without changing your wire. 4 gauge OFC (Oxygen free copper) is meant to handle around 100 amps. Given your situation, who knows what you're running. It could be CCA (copper clad aluminum) which has more resistance than copper. It could even be offsized 4 gauge CCA, meaning whoever manufactured it put 6 or 8 guage CCA in a 4 gauge sleeve. You can read about the differences between CCA and OFC here: http://caraudiomag.com/articles/copper-wire-vs-copper-clad-aluminum-wire-wire-warnings What you need to do is upgrade your electrical. Start out with some wire. 1/0 Run a positive from front to back, fused. Run a negative from front to back. This is called an isolated ground. http://www.audiosavings.com/products/Car-Amplifier-Power-Cable/CADENCE-0-GAUGE-BLUE-AMP-POWER-WIRE-49-FOOT-SPOOL-NEW/0G15M-BLUE.aspx After you get that, Fuse it up for 150 amps. Grab a multimeter and test your voltage at the amp. If you're dipping into the 10s, fuse lower and turn your amp down. Most cars can hang with around 1500 RMS on stock electrical. Low voltage will burn amps up, send them into protect, make them run hot, etc. Little food for thought @ 12 volts: 100 watts ~ 10 amps draw 1000 watts ~ 100 amp draw @ 120 volts: 100 watts ~ 1 amp draw 1000 watts ~ 10 amp draw The lower the voltage, the more strain on your electrical itself. Higher voltage = more power with less strain. Run 100 watts off 18 volts and run 100 watts off 12 volts with the same wire. You'd be pulling ~30% more current off 12 volts than you would off 18 volts, while producing the same power. Good luck man... Trunk Build Log
Blackedout Posted June 8, 2011 Report Posted June 8, 2011 ok... some important info is being left out or communicated poorly here. 4awg should NOT get a 200amp fuse. i wouldnt go over 100amps. 125amps if you know you have good OFC wire. now that amp can draw something like 150-200 amps so you can burn up that 4awg wire. and that can burn your car down, no joke. so like the others said. you need 0awg wire and a 250amp fuse. im guessing you will probably buy cheap wire so i wouldnt go up to 300amps. Lol... looks like we were on the same page. Car-B-Ques suck. Trunk Build Log
skittlesRgood Posted June 8, 2011 Report Posted June 8, 2011 ok... some important info is being left out or communicated poorly here. 4awg should NOT get a 200amp fuse. i wouldnt go over 100amps. 125amps if you know you have good OFC wire. now that amp can draw something like 150-200 amps so you can burn up that 4awg wire. and that can burn your car down, no joke. so like the others said. you need 0awg wire and a 250amp fuse. im guessing you will probably buy cheap wire so i wouldnt go up to 300amps. Lol... looks like we were on the same page. Car-B-Ques suck. ya, tires and paint burning make the marshmallows taste funny. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Mtnbikecrazy55 Posted June 8, 2011 Report Posted June 8, 2011 This is a great starting point if you are unfamiliar or confused about fusing. http://www.stevemeadedesigns.com/board/topic/1005-wirefuse-guide/ As said previously, don't put a 250a fuse in the 4awg. Because that basically makes the 4awg the fuse and it's going to smoke first. Upgrade that wiring to 0awg. Boom. Sidenote, how muck 4 awg do you have and what brand/type is it? I'm going to need some to wire my RF 500.1 I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback
trjohnst Posted June 8, 2011 Author Report Posted June 8, 2011 Well I have 2 4guage wiring going to the back for 2 amps. 1 brand is Rockford, and the other brand is that crappy Scosche. So, the answer to what I asked for, is that my amp was pulling more amps than my fuse, so it blew. I will need to buy a few 150amp fuses, until I have enough $ for 0 guage runs. I will be doing a big 3 in a week or 2, but wont be adding another battery because I have a stock alternator and its pretty old (stock 80 amp alt.). Thank you all for the input. 1991 Accord Audioque HDC3 15" (Copper)<--Sub Audioque HDC3 15" (Copper)<--Backup Sub Crescendo BC2000D<--Amp Big 3 1/0 Knu<--Wiring Eonon 3.5" DVD<--Headunit Infinity Kappa Perfect<--Mids & Highs 2nd Stock 80Amp alt. 1991 Mustang 5.0 Too many mods (Sold) 1991 240sx SR20 Red Top Too many mods (Sold) 2004 GTO Just starting mods
