Connect it to ur MAC via Bluetooth that's what Kk going to do
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
What i used to tune mine was to get my old laptop out and reimage it and set it up for windows xp 32 bit. I tried it with windows 7 32 and 64 bit and it worked but right in the middle of tuning, it would disconnect the connection i had with my 3sixty.2 and i would have to reconnect to it. Total pain in the ass.
Right now i have a laptop i may put in my truck as a car-puter and it is just windows xp media center edition with sp3 installed. Its a dell inspiron 1521 notebook pc with a 15.4" screen. I have not had a single problem using it on xp, only like i said with windows 7. Even when i tried the compatibility mode within windows 7, it still disconnected my 3sixty.
And if you need help with tuning it let me know, i used the tpi 440 plus oscope since i bought it a few months back online and used audacity to create test tones for it. Then i set the gains with a 1KHz test tone and set the subwoofer gains on the 3sixty with a 40Hz test tone. Also before you set the 3sixty, ensure you flatten out the eq completely on your HU and 3sixty. Once the gains were set i went into the 3sixty and selected a new file of creating a OEM setup, even though i have a aftermarket headunit installed. The OEM will automatically adjust the eq to try and flatten it out the best it can, aftermarket you have to do yourself. Then after that was said and done i did some fine tuning by ear and im going to stop by at a local shop and get on the termlab and use the RTA they have like meade did to tune it even further.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
360.2 will not, WILL NOT work with mac/apple phones, computers or pad/tabs...
If it did I would have one now running my sh*ty system. I had a shot at a free one b4 I knew what it was but since it ain't work with my macs I gave it back.... Now if you get the 360.3 it will work with mac/apple gear!
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
I use a HP Mini...works great and I can store tons of music on it for in car use.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
i was thinking about getting a palmone thing and use that as like a remote for it and the manual makes it seem pretty easy to use with a palm. i am thinking of the tungsten e2 any thoughts on using a palm or windows mobile device?
you win some, you lose some
I tried to get mine working on my HTC Ozone phone i had and it was a epic fail. It would find my device and connect but i could never get the damn drivers working on the phone. Palm is your best bet if you want it to be handheld.
