SpartanSound Posted June 16, 2011 Report Posted June 16, 2011 Can I ground my extra deep cycle battery in the trunk to the same ground as my amp (which is a seatbelt bolt for now), or should I run some 1/0 from the negative on my stock battery to the negative on my deep cycle battery in the back? Where should I ground it at?
memphisBred Posted June 16, 2011 Report Posted June 16, 2011 I personally would ground the amp to the back battery. Then have a ground from the front to the back battery. But that's just me. Many ways to do it including the one you threw out there, but I don't like seatbolt grounds. SMD Super Seller/Buyer Audison----Hertz----Rainbow
Tarball Posted June 16, 2011 Report Posted June 16, 2011 Can I ground my extra deep cycle battery in the trunk to the same ground as my amp (which is a seatbelt bolt for now), or should I run some 1/0 from the negative on my stock battery to the negative on my deep cycle battery in the back? Where should I ground it at? I would ground the rear batt(s) in the rear on the frame. I've done seatbelt ground before and thought it "works" route it to the frame somewhere to do it right. Also, should be fine to ground the amp at the same FRAME ground point. If frame ground is not an option then run the 1/0 to the front. /Cheers CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
SpartanSound Posted June 16, 2011 Author Report Posted June 16, 2011 Great stuff guys thanks for the help!!
RooTxBeeR Posted June 16, 2011 Report Posted June 16, 2011 DO not ground to the seatbelt, it is the worst spot you can possibly put it. As they said ground to the back battery, then run a ground from your front to back batteries neg. If not that then ground it to the strut tower. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
