shotime216 Posted June 20, 2011 Author Report Posted June 20, 2011 can we please get a picture of the wires going into the amp? The diagram you showed displays you running the amp at 2 ohms bridged which means trouble for your amp. I have them wired like that just not bridged. I know not to bridge them
shotime216 Posted June 20, 2011 Author Report Posted June 20, 2011 OP, how did either of y'all set gains? I set them by ear. I dont have access to a DMM or a O Scope. He set his by ear as well.
finkster Posted June 20, 2011 Report Posted June 20, 2011 So you are only wired to one side of the amp? A pic would be a huge help. You should wire the right 2 speakers and the left 2 speakers in parallel to make it 4 ohms each side of the amp. The way you have it explained is 2 ohms...which doesnt make sense. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
shotime216 Posted June 20, 2011 Author Report Posted June 20, 2011 So you are only wired to one side of the amp? A pic would be a huge help. You should wire the right 2 speakers and the left 2 speakers in parallel to make it 4 ohms each side of the amp. The way you have it explained is 2 ohms...which doesnt make sense. I have them wired that way(the right 2 speakers and the left 2 speakers in parallel)Im having problems with my phone so I can upload any pic right now.
JMZNeal Posted June 20, 2011 Report Posted June 20, 2011 then your running 4 ohm stereo. 125 per channel. 62.5watts ish per speaker. that is probably the best that amp will sound for you as long as your gains are set properly. Now. what amp is your "friend" running on his and how are they wired. he's probably got his mono at 2ohm or is running 4ohm drivers where your's are only 8ohm. JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
shotime216 Posted June 20, 2011 Author Report Posted June 20, 2011 then your running 4 ohm stereo. 125 per channel. 62.5watts ish per speaker. that is probably the best that amp will sound for you as long as your gains are set properly. Now. what amp is your "friend" running on his and how are they wired. he's probably got his mono at 2ohm or is running 4ohm drivers where your's are only 8ohm. He has the same speakers as I do.
SoCaLBaMF Posted June 21, 2011 Report Posted June 21, 2011 What amp does HE have?? 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
homiewes Posted June 21, 2011 Report Posted June 21, 2011 your friend is a fucking idiot for saying that more watts = less sound...he might just have his installed differently, and placed better. LMAO!! To be real his speakers are in the same location as mine. He installed them in his car. He keeps saying if I give him $100 dollars he will rewire mine to sound like that. Im trying to figure out what other way he could have wired them. if hes a good friend he would not be such a dick fuck and charge you 100 dollars lmao My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
uhoh_45 Posted June 21, 2011 Report Posted June 21, 2011 so your running 4 speakers on 1 channel like so ?? maybe try doing 2 speakers per channel R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
