Hi guys, I recently started a thread about getting a new alternator as my current alternator is on it's way out. We are still contemplating on either replacing it with a OEM replacement, or getting a DC OEM 190amp alternator. The price difference is what is stopping us right now.
Checking the battery lately it's resting around 12.2-12.4, which if I'm not mistaken it should be resting at about 12.6 right? It's a duralast battery that's been in there for about 5-6 years so I guess it's getting towards the end of it's life, not too big of a deal.
My question is, is there a better battery I should be looking at to replace my stock starting battery??
Thanks guys!
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
Sorry to bump it so early, but I really need a response soon as possible...I don't think this battery is going to last much longer..
First System
Posted (edited)
kinetic, xs power all good brands. OEM alt will do just fine if you dont have much money to spend
btw, why do you need H/O alternator? you gonna run 800wrms amp..
Edited by IAmLegend
I was looking at a H/O alt mainly because I'm running 3 HID harnesses along with my system, basically just a precaution. I'd rather have more juice then necessary rather than not have enough...right?
Are there certain xs or kinetic batteries that are made specifically for replacing stock batteries?
First System
depending on what size battery can fit in the stock location, or you can always cut a few brackets haha. but i replaced my stock battery with a kinetik hc1400 and it rests at 13.2v measure what can fit in there and then search online most of the websites will have dimensions
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
any battery will work for you as long as its a 12v. just pick the biggest one the fits your stock location and budget. i think an oem alternator would be fine if your only running 800rms and 3 HID's since the HID's are prob 55w each so that would leave you at 950 watts
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
I would upgrade the battery first. Get a good XS that can fit under the hood and do the big 3
Posted (edited)
I just ordered all the wiring I'm going to be needing to do the big 3, in all 0 gauge.
What is a good XS battery for my application?
I've been looking around at batteries and I'm seeing that NGT Extreme batteries are a pretty good bang for the buck, along with Deka Intimidators?
Any ideas?
Edited by billy101
First System
to find a battery just measure your stock battery's size and then find whatever xs, kinetik, ngt etc. will fit in that same spot
Build Thread
UBL
1948 Plymouth
  • Who's Online   0 Members, 1 Anonymous (See full list)
