'91 Civic Hatch | (1)15" on 500 watts 31Hz | Low Power Bigger Output
Got some video taken today, the camera wasn't the same as the last videos, so bare with it :/ I got in my car today and went to start playing, and the amp wouldn't turn on, so I was like wtf. took me forever, but it turned out the power wire to fuse holder for the pos on the battery, had fallen out and it only moved a inch away so at a glance I didn't realize it. I took a pic though once I had figured it out,
Once the video is done uploading, I will post it.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
The video is up!
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
A while back I had noticed that air leaks through the holes in the basket for screws. So today I went and ductaped it up, and I must say, I barely had any leakage but any leakage makes a big difference in output.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Today I went and cleaned up my wiring. Along with all that I took out my ground and soldered the wire to the clamp ring. Since I have one sub that is inverted and one that isn't when I take off the wires I have to test to get the polarity right. So this time I took some extra wire and soldered it so I have black/red at the end of each set of wires for the subs. Here are the pictures.
Here is where I put the red/black at the ends
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
New video
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
i dig the box man for sure.. turned out nice..
looks like you got a pretty clean honda too.. rust wise n such..
i got a customer coming thru tomorrow same car as yours but he wants me to build a box for his 2 audiopipe txx be 10s and a audiopipe 1000d. might get loud
Thanks, I had a few hick-ups, but it did do well, all sealed up and no leakage. Only rust I have is a small spot on the back of the hatch and a bit by one of the rear wheel wheels on the outside. That should get pretty loud, mine is pretty loud for what it is, so that should definitley hit hard.
Build wise
I have been putting together a parts list for a looong time, and I am pretty close to finished. Here what i am looking at so far
HU:Need a new one and un-decided, anyone got some suggestion? Just looking for something normal with aux/usb port, not worried about a cd player.
Subs:Stuck between 2 SA-12's and I build a custom box with a center port that is pretty much a T I guess, tuned to 32Hz. On the other hand I have the Skar vvx-12(2) + Custom box for $360, which is about 30-40 cheaper than 2 SA-12's. Dual 4 ohm option
FrontSpkr:Rockford Fosgate T1652-2 comp, using factory 6.5 mount and contemplating a custom glassed mount for on top of the dash.
RearSpkr:Rockford Fosgate T1693 on a Custom mount that will be branched off of the Sub box
Sub Amp: Rockford Fosgate T1500.1bdCP running at 1 ohm to the subs
High/Low Amp: Rockford Fosgate T600-4 for the rest of the speakers.
Electrical
HO Alternator: looking at mehcman 225A but damn pricey, looking for something lower than that.
Batts: I am looking for a battery to replace the front stock battery. Then I am looking for 2 smaller battery that are either the length of a normal battery, just half the width, or little smaller sized ones to fit in the back, on either side of the sub box.
Wire: All Knu Koncepts KCA 1/0 Awg wire, big 3 and 2 runs to the back, one pos one neg, and between the 2nd and 3rd battery, from the 3rd battery will go to a distribution block, then to the amps.
Will be getting their speaker wire to, and some 12awg for sub speaker wire. If I can get more money, I will do in all OFC wire
RCA: Dependant on if I get an EQ, or a PAC LC1, will determine if I get 4way or 6way RCAs. If I get nothing, I will get a 6 way so its easy to run to the back, all channels. If I get a PAC LC1, I will get a 4way and 2way, 4way for front/rear then the other to PAC LC1, then from their to the sub amp.
Deadener: Looking at alpha damp if I can get the money, if not I will be getting that Damplifer Pro.
I want to try and move the back part of the back seat up a inch or two, so I can gain some more depth for my max dimensions. Along with all that, I want to incorperate some fan work like steve did under his box where all his amps where. I want to create an airflow in the back where the amps are, so they don't sit in stale hot air.
Come on everyone, I don't get to much feedback from anyone. I would love to hear everyones opinions on their own experiences and personal choices. As far as videos I need to get a hold of a better camera before I can really show anything that is good.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Got a new video with a new camera, See a lot more shirt movement. Still moves more than it shows but oh well.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Space issues, I could only cut a certain length for each piece of wood within the sheet. If I cut another longer I would need a 2nd sheet, so I just did it like this. No difference other than looks, and you switch the + and - on one sub.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   2 Members, 0 Anonymous, 1073 Guests (See full list)
