where are you located.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I ran power and RCA'S on both sides of the truck. Each side is for each amp.
keep both power & grounds on 1 side, rca's on the opposite side.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
you do not have to do this unless oyu have jank rcas. Is it a good idea? yes. is it absolutely needed? no.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Gotta love the good ole pioneer humm.
I do this to every pioneer I install.
Call it ghetto if you want but its inside the dash so i couldn't care less about how it looks, it simply works.
why do you do this?
Edited by IAmLegend
I'd call it creative ingenuity.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
This is what I thought as well. I have shielded rca's which have a separate grounded shield around the outside of the inner wires. I have an electrical engineering buddy who says it will still cause noise even though I'm grounded. I still do run them on opposite sides for good practice, but to me a grounded shield should kill all electrical noise.
why do you do this?
To ground the rca's out. Pioneers have a pico fuse in them that pops and causes ground noise, so when I'm installing 6 channels of rca's for someone I don't want to have to pull out their head unit after installing it just because of ground noise. If you've ever put 6 good rca's on a head unit then tried to fit it in a dash you would completely understand why I do this.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Well you tell me cause I really don't know, all I know is the RCA'S are all monster brand. They are all shielded, that's all I really know. They cost me like 50 bucks each lol
They should be fine IMO. The noise you're getting is being generated by the head unit, ground your rca's like I've shown in the picture and the noise should be completely gone (as long as your h/u has a good ground too).
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
why do you do this?
because of a fuse inside the amp. it'll pop if you short your RCAs or hot swap RCAs. grounding the RCAs to the chassis bypasses that fuse and makes a good ground.
how loud is this hum?
you said "master and slave" but then said each amp is wired to 1ohm. if you are not strapping the amps then you dont use master and slave. they are both master.
  • Who's Online   0 Members, 0 Anonymous, 1573 Guests (See full list)
