big 3 upgrade question
jroshandtap
alright finally got my amps figured out, and i finally the 1/0 gauge wire but im not sure as to were to mount the engine block wire. I have a 2005 ford explorer and im just not sure as to where i should tie this wire into the engine block. obviously the ground from battery and alt. wires are pretty easy but i just wanted to know if any of you have my vehicle and did the upgrade to your systems and if so how do you install the engine block wire. thanks for your help
Hey I am not too sure on the exact location but have you checked out the thread below? Maybe same place as the stock wire?
Big 3 Tutorial
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
I installed it. I just took out the stock 8 gauge wire from the block to the battery and replaced it with 0 gauge. Simple as that
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
thanks for the input, but i dont know if im just overlooking the engine block ground or what, but i cant find it lol so if you guys happen to have pics of where the wire is located on my vehicle i would really appreciate it
it says in the tutorial that you can use any engine block bolt but its recommended that you use the existing bolt. if you guys cant get pictures of your install can you tell me if your is on the right side or left side of the block? XX79 you said you installed it on the same vehicle right?
just go from alt bolt
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 584 Guests (See full list)
