so ive had my amp for a while now and ive been getting this weird problem with it, so what happens is when the amp turns on the green light on the amp dims and will slowley go out then turn off but the weird part is that its getting 14.4v then when the amp turns on it drops to 8 volts, and whats weird is that sometimes the amp does work and it gets the 14.4v but then all of a sudden it gets 8 volts the ground is prefectley fine. has this happened to anyone else its an audioque 2200
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
very strange, if your getting voltage drops that means your electrical must be bad.. alternator / wiring or something..
My youtube channel, please subscribe
http://www.youtube.com/ballinblaza
the thing is though i have all 0 guauge and a high output alt
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
something is probably loose in the amp causing it to randomly pull voltage like that, kinda like a short in it.
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
I would think it would be some regulator in the amp, or the voltage regulator in your alt. But if everything else is working with your car, such as the head lights, battery light on the dash, etc, then it shouldnt be your voltage regulator. Check your 0 gauge wire all the way to the battery, and make sure it has no tears in it where it is touching metal or the chassis. If this is happening, it could be cutting the voltage. Another idea is your fuse, try changing it out and seeing if that helps. The fuse could see all the power and not be able to handle it due to a defective fuse, then it could give up and drop voltage, causing the amp to shut off.
1991 Accord
Audioque HDC3 15" (Copper)<--Sub
Audioque HDC3 15" (Copper)<--Backup Sub
Crescendo BC2000D<--Amp
Big 3
1/0 Knu<--Wiring
Eonon 3.5" DVD<--Headunit
Infinity Kappa Perfect<--Mids & Highs
2nd Stock 80Amp alt.
1991 Mustang 5.0
Too many mods
(Sold)
1991 240sx SR20 Red Top
Too many mods
(Sold)
2004 GTO
Just starting mods
i allredy checked my run of 0 gauge and there are no tears i think im just going to contact audioque and ask to send it in for repair
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
where are you measuring voltage? amp + and - or are you measuring the remote voltage? does voltage still drop randomly with the amp unhooked?
It sounds like the amp has a loose piece inside. Maybe just wasn't settled in when it was made. Just unfortunate is all
im getting the readings from the amp and the remote and no i dont get the voltage drop at the amp when the amp is unhooked when the amp is off i get a perfect 14v
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
  • Who's Online   0 Members, 0 Anonymous, 908 Guests (See full list)
