Those amps come alive around .185 ohms .... BIG POWER
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Ive ran a pair at .25 daily, On 3 batteries.
Either way they are powerhouses and damn near bullet proof
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Looks great man! Seriously bad ass and you work quick ;)
Couple things if you don't mind...
You want 1 frame ground per alt (so 1 per alt to frame and then 2 frame to battery). I only see 1 ground in your pics on that battery, there should be at least 2 (assuming the alts are grounding to the frame).
What most people don't understand is that most of the OEM alts you see use the same parts (for GM anyways). The main difference comes into play in regards to how they are put together which is actually a pretty big deal. Like everything there are cheaper parts that they can use, but your alts are 250's so it is less of an issue than say a 300 or the like as there is less heat.
For example, Iraggi sucked balls (I had 3 fail in 4 months and he stole my dual alt bracket) because he would sand blast the cases with the fucking bearings in them so that is why so many people had bearing and rotor issues. I guess he didn't have the tools to press in the bearings or just got lazy towards the end. There is also a situation in regards to those same bearings and how they are pressed where you get some wobble which over time can wallow out and cause a failure. He also used some POFS staters, pulleys that were too small, and the list goes on.
For $190 an alt it's well worth the test IMO (just double check that pulley is small enough). Even if they blow up and you want to try another manu, be it Mechman, Ohio, DC, etc. you can just have those rebuilt. If I had to guess I would say $225+ to rebuild (through say Ohio) so that's $415 an alt total or get the parts and do it yourself if your feeling strong. ;)
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
How does it sound? :)
It sounds good. Got my gains set this evening, so I felt a little better about cranking it up. I got a little bit of a hair trick with it tonight, even with two breakers tripped which left me running on 2 amps and 2 subs. I need to check my ring terminals, I think I need to recrimp and solder a couple to fix the tripping. Even with only 2 subs running it still blurs your vision and makes it feel impossible to swallow while it's hitting.
Good to hear man, videos?
