DRauck Posted July 22, 2011 Report Posted July 22, 2011 my friend said face it forward and ported with ports to the side Well if you trust him then go for it. Good luck! You can always build another box if you are displeased with how it sounds Edit: But seriously you don't have room to port it and will probably damage your subs. 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
MuRKRoW Posted July 22, 2011 Report Posted July 22, 2011 my friend said face it forward and ported with ports to the side Well if you trust him then go for it. Good luck! You can always build another box if you are displeased with how it sounds Edit: But seriously you don't have room to port it and will probably damage your subs. I agree. Just build the damn box and stop hesitating. We can't watch you build it or tell you EXACTLY how each cut has to be made. Build it and see if it sounds good. If not, then build another one a little differently. It's your setup, not anyone elses... Sound Solutions Audio ZCON 18 Crescendo Audio BC3500D JVC KD-R80BT headunit Alpine/Pioneer mids & highs 4 group 34 agm batteries Knukonceptz 3x0ga. terminals Kicker/XS Power 0ga. wiring
BassMunky Posted July 23, 2011 Author Report Posted July 23, 2011 yes, but wanted opinion on what would sound the best and loudest Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 26, 2011 Author Report Posted July 26, 2011 ok will seee how backward will work Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 26, 2011 Author Report Posted July 26, 2011 We made an mdf ring that went around the sub and then cut it into 4ths. So like we took the ring and cut it in 4 pieces and used 2 on each side (one on each side of each sub like on the picture). I hope that makes sense. As for space, you'd be right on. This is with subtracted 1.5" for your trim rings which should be doubled up MDF to make it 1.5" in thickness This is with subtracted 1.5" for your trim rings which should be doubled up MDF to make it 1.5" in thickness what you subtracted from what? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 26, 2011 Author Report Posted July 26, 2011 remeber now i need atleast 6.5 of mounting depth. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
DRauck Posted July 26, 2011 Report Posted July 26, 2011 remeber now i need atleast 6.5 of mounting depth. With the angle I think there should be enough clearance. If not, mount the subs lower? 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
CleanSierra Posted July 27, 2011 Report Posted July 27, 2011 Just give up, I don't think your advice will be used. Im not the one you want to try to troll. Just a fyi for you.
BassMunky Posted July 28, 2011 Author Report Posted July 28, 2011 It will people just was worried about the 1.5 thickness of the mdf .75 for the top anb bottom. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 31, 2011 Author Report Posted July 31, 2011 what wood suggest? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
