MrJustinDanger Posted June 29, 2011 Report Posted June 29, 2011 I have no idea where to mount this amp...The back of my set does not lay down and I dont know where else to put it! http://tinypic.com/r/35259qo/7 http://tinypic.com/r/25q80gw/7 http://tinypic.com/r/161kjnp/7 http://tinypic.com/r/2vry15k/7 Quote
MrSkippyJ Posted June 29, 2011 Report Posted June 29, 2011 whats wrong with where it is? Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
blownengine Posted June 29, 2011 Report Posted June 29, 2011 Build a rack to put it in one of the corners behind the wheel. Either a simple wooden rack or fiberglass it. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
Azagtoth502 Posted June 29, 2011 Report Posted June 29, 2011 If you leave it on the box, use rubber washers or similar. Quote pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
MrJustinDanger Posted June 29, 2011 Author Report Posted June 29, 2011 whats wrong with where it is? It isnt mounted right there. Just sitting on top of the box. Would it be a bad idea to mount it to the box? Quote
MrSkippyJ Posted June 29, 2011 Report Posted June 29, 2011 If you leave it on the box, use rubber washers or similar. or make a good box that doesn't flex/vibrate much Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
MrJustinDanger Posted June 29, 2011 Author Report Posted June 29, 2011 Build a rack to put it in one of the corners behind the wheel. Either a simple wooden rack or fiberglass it. Its a little too long to fit into that spot :/ I thought about that too! Quote
MrJustinDanger Posted June 29, 2011 Author Report Posted June 29, 2011 So if I use rubber washers the amp should be okay? Quote
18abVFL Posted June 30, 2011 Report Posted June 30, 2011 build a rack on the other side of the box, angled facing the cabin. Quote 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
june318 Posted July 4, 2011 Report Posted July 4, 2011 you could put a sheet of wood up against the back wall to mount it on. Quote http://i910.photobucket.com/albums/ac310/june318/100_1236.jpg
