problem with amplifier?
Hey guys
I just got my new HU, hooked everything up but it doesn't sound too good. I got 2 sa10 with hifonics brz1200.1d. The box is in the trunk of bmw325i which is sealed from inside. the gain is turned uo 3/4 way and rest of the settings i didn't touch. I order to get subs moving i need to turn my HU to 25/35 which makes it really loud inside, but i don't hear lows that well from subs. Also, voltage does not drop below 13.8.
here's a quick vids i made. Tonight i'm gonna set it up with AC volt meter.
in second video you can't really see steering wheel and doors flex little bit.
did i set something wrong or what?
HELP :trippy: :trippy: :trippy:
Edited by IAmLegend
Just mess with the equalizer on your HU tune down the highs and mids a bit haha
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
None of the pressure is getting into the cabin so it is all staying in the trunk, you'll need to find a way to get some of the pressure into the cabin. Do you have fold down seats, if you do then fold them down if not you'll need to find another way.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have to 2nd this. If your trunk is sealed from the cabin, and the subs are firing into the trunk, you will not hear them very much. Now, if they are firing into the cabin, that is a different story. Can you elaborate?
97 Maxima SE
Bunch of shit going in, check out the build
trunk is sealed from cabin, only way is to cut out hole and stick box thru it.
if u have the ski hole covered cut it out i did it in my bmw and it made a world of difference
Current vehicle
91 Lincoln T.C.
2 18s trunk build coming soon
for now
2-12s ported in trunk
1000 watt kenwood amp
kenwood deck
18 inch rims
  • Who's Online   1 Member, 0 Anonymous, 1588 Guests (See full list)
