There are a ton that van handle .5 daily, but probably wot last as long if they were just run at their real 1 ohm rating. But I wouldnt suggest it for most daily applications unless you know what you're doing.
DC 12.0k ;)
The 12.0kw competition series amplifier is a 12000 watt amplifier. It is capable of running up to 16 volts for up to 13000 watts. It is a 2 channel amp and is designed to run at 0.5 ohm per channel or 1 ohm bridged. It comes with a bass knob. For power inputs it will accept triple 0 awg for power and triple 0 awg for ground.
Key Features
• .5 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• 2 channel
• Triple 0 awg power and ground inputs
We recommend for installation
• 1 upgraded battery under the hood
• 3 extra 800ci battery in the rear
• Minimum of two 0 awg ran from the front battery to the rear batterys
• All 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 6 runs into the amp
• 2 upgraded aftermarket alternators
• Dash mounted voltage meter
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
RD Audio D9.... for sale :)
Team DC Audio : Team Shok : Team NWSPL Co-Founder
Head: Pioneer AVH-P5200DVD
Front Stage: Morel Tempo 6.5's/ CDT 6.5's
Subs: (4) 15'' DC XL's, 15 cubes @ 38hz
Sub Amps: (2) Shok 5k's
Speaker Amp: Shok 100.4
Wiring: Shok Industries 1/0
Electrical: White Mechman 270/Adjustable Voltage/3 Shuriken BT120's/3 XS XP3000's
FPiYT.jpg?9395
hope your electrical is beyond ridiculous.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
AQ, DD, DC, orion ( older) sundown cresendo american bass lanzar opti
theres more.. thats just off the top of my head
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Boss, lanzar, and power acoustiks are all like .001 ohm stable and do like 470,000 wrms or so... That's what the box says at least?
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
