ABC Posted July 7, 2011 Report Posted July 7, 2011 is it ok to run my old battery up front( no clue what it is) and then get a XS d3400 for the back? i heard it wasn't good to mix AGM and non AGM batteries together. that true?
Louisiana Bass Posted July 7, 2011 Report Posted July 7, 2011 Dude, what's up with the 50 threads a day shit? How about you just use the search function and read up on some stuff. N8. No homo...unless you want there to be.
6berry Posted July 7, 2011 Report Posted July 7, 2011 yeah u should try to search first then ask as everythings been covered a million times but to answer your question no you shouldnt run an AGM with a non AGM. change your front battery to whatever fits then add another rear battery later if you need it 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
Namosh Posted July 7, 2011 Report Posted July 7, 2011 I've been running a normal battery under hood and a D3100 in the back for some time now. Doesn't seem to cause any problem. My Ram Quad Cab Blow-through
Dan2427 Posted July 7, 2011 Report Posted July 7, 2011 Same as namosh no problems here. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
rickyfromthe407 Posted July 7, 2011 Report Posted July 7, 2011 I have been running a regular Everstart..think thats what its called 51-R up front in my Civic with a XS D6500 in the back. For round 7 months id say now. No problems. But i do believe I have read somewhere ( cant find it now of course ) that it is not good. Because iirc they said your alt will charge your AGM battery to its peak then quit charging before ur front battery is full or something like that.. But I have never woke up to a dead battery - & Never been stranded anywhere - Hell never dropped below 12.6v in 7 months. I see no problems. Money well spent. But hell, id do it... Current 4 10"s System! 1/0 Power Wire All Around + Big 3 - $140 Rockford Fosgate T2500-1BD - MSRP $1800 (4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200 XS D6500 $245.65 PIONEER AVH-P5200DVD 7" Head Unit = $430 Soundstream SC-6T Component 6.5" FRONT $60 Pioneer TS-A1673R 6.5" REAR $85 A Bangin system! = PRICELESS!
