my amp is a Alpine V12 MRV-F250, specs on power
- RMS Continuous Power output
25 watts x 4 @ 4 ohms, 0.08% THD
35 watts x 4 @ 2 ohms, 0.3% THD
70 watts bridged into 4 ohms, 0.3% THD
- Dynamic Power (@ 14.4V, 20 Hz to 20 kHz)
40 watts x 4 @ 4 ohms, 0.08% THD
50 watts x 4 @ 2 ohms, 0.3% THD
100 watts bridged into 4 ohms, 0.3% THD
I have them wired Like this. I would like to wire them like this. Is the 2nd one the equivalent of running at 1Ohm? If so this amp is only stable down to 2 Ohms.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Can you bridge each channel on your amp making it a 2 channel? If you can then that would make it run as a 2 channel amp at 2 ohms. If you can only bridge it into a single channel then you would be wired down to 1 ohm which would probably cause problems for your little amp. either way i would suggest getting a new amp
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
2nd way would be too low of an ohm load. Your amp can only do 4 ohms bridged, not 2 ohms bridged.
actually hes right but you could wire each sub in parallel going into its own channel. so you have 2 empty channels but youll still be getting more power from your amp
Build Thread
UBL
1948 Plymouth
Oh well, if those are the Power specs, and I wire it 2 x 2 ohms, It would get more power than 2 x 8 Ohms bridged?
Edit: I think I would see the same power between the 2, would there be any difference running at 8 ohms, to 2 ohms? Because if I do this, I can put my rear 6x9 on the other 2 channels. WHich would help a lot to drown out a lot of the rattle.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
bump, wanna know if there will be any differences between the ohm switch.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   1 Member, 0 Anonymous, 2694 Guests (See full list)
